Hi Guys,
I am new with librenms, i got this error when update the latest version.
How i can solve this problem below :
Component | Version |
LibreNMS | 1.30 |
DB Schema | 203 |
PHP | 7.0.21 |
MySQL | 5.5.52-MariaDB |
RRDTool | 1.4.8 |
SNMP | NET-SNMP 5.7.2 |
[FAIL] It doesn’t look like Net_IPv4 is installed
[FAIL] It doesn’t look like Net_IPv6 is installed
[FAIL] Database: incorrect column (ports/ifTrunk)
[FAIL] Database: extra column (sensors/entity_link_index)
[FAIL] Database: extra column (sensors/entity_link_type)
ALTER TABLE ports
CHANGE ifTrunk
ifTrunk
varchar(8) NULL;
ALTER TABLE sensors
DROP entity_link_index
ALTER TABLE sensors
DROP entity_link_type
[FAIL] Discovery has not completed in the last 24 hours, check the cron job
Thanks.
