The VRF details are presently not implemented. I looked at the git file history and it seems like the ‘details’ functionality was removed in one of the latest commits.
Is there an estimate on when this feature will be implemented again?
Why was it removed?
Thank you
Which commit? What device/os? I have no idea what you are talking about. Please provide more specific info.
The output of
routing/protocol=vrf/view=detail/vrf=“some_VRF_name”/
is:
‘Not Implemented’
File html/pages/routing/vrf.inc.php lines 176, 177:
} elseif ($vars['view'] == 'detail') {
echo "Not Implemented";
I can’t see any details for any VRF.
Looking at https://github.com/librenms/librenms/pull/8889
All info seems to be displayed on the normal page. Probably would be better to just have the same content displayed for “basic” and “detail”.
This is correct
the detailed view is still to be written. But before that, it should be defined what we want to see here.
What would probably make sense would be to have all the routing data of the VRF (so not only the interfaces but BGP, OSPF etc etc. As murrant said, the standard vrf info is already in the normal page, so having both with same information does not add much.
In the meantime, I would say that you can ignore the detailed view
PipoCanaja
