Warning: Global lnms shortcut not installed
today I got this warning:
Warning: Global lnms shortcut not installed. lnms command must be run with full path
Fix: `sudo ln -s /opt/librenms/lnms /usr/local/bin/lnms
I run the sugestion, but still got that error, any clue to fix it?
Am having the same issue since yesterday, i deleted the file and recreated it but the same error occurs.
How do i fix it?
Yes I did the same, still error
Same here on 4 installations.
That validation is new. What does which lnms show?
I have the same issue.
Seems that user librenms donā€™t have permissions to /usr/local/bin/lnms
[myusername@serverX ~]$ which lnms
/usr/local/bin/lnms
[root@serverX ]# sudo -u librenms which lnms
which: no lnms in (/sbin:/bin:/usr/sbin:/usr/bin)
i try to chown librenms:librenms in /usr/local/bin/lnms, not root, also falid.
is this a bug on this version?
(1.70.1-1-ga3635d0 - Thu Dec 03 2020 23:33:26 GMT+0800)
Same error here.
But also that if i in (Linux centos8) Root mode on the server i canā€™t do ./validate.php any more.
I receive then the following:
Do not run validate.php as root
The problems are started after update to 1.70.1 which a received on Wednesday 2-12-2020.
wow, so /usr/local/bin is not in the PATH for the librenms user??? Which distro is everyone having issues using?
Jorg, guess what. You should not run ./validate.php as root :smiley:
ęœŖ命名
Centos 7.X
Using Centos 7
Also seeing this same issue currently. Not sure how the check is being executed, but linking to lnms even in the paths that are available to the user doesnā€™t pass validation and adding /usr/local/bin to the users path has no affect.
CentOS Linux release 7.8.2003 (Core)
Iā€™m seeing this issue in CentOS 8. Sort of. It does not appear when I run validate.php from bash using the LibreNMS user. It does show up running Validate Config from the LibreNMS web page itself.
For reference:
[librenms@librenms ~]$ echo $PATH
/usr/local/bin:/usr/bin:/usr/local/sbin:/usr/sbin
[librenms@librenms ~]$ which lnms
/usr/local/bin/lnms
[librenms@librenms ~]$ ./validate.php
LibreNMS  | 1.70.1-1-ga3635d0b7
DB Schema | 2020_10_12_095504_mempools_add_oids (191)
PHP       | 7.4.13
Python    | 3.6.8
MySQL     | 10.3.17-MariaDB
RRDTool   | 1.7.0
SNMP      | NET-SNMP 5.8
[OK]    Composer Version: 2.0.7
I solved this by adding a ln to /binā€¦
sudo ln -s /opt/librenms/lnms /bin/lnms
Now the validate passes without error.
unfortunately this doesnā€™t appear to resolve the issues for me. The web interface still displays a warning on the validation page. The librenms user can see the lnms link based on the output from which lnms but I still have the error. CLI validate.php passes without issues
You are right. I only checked the validate.php from CLI. Not from validation page.
So I ā€œalmostā€ solved the issueā€¦:wink:
I just installed a New LibreNMS on CentOS 8 (Ngnix). I am having the same issue. WebUI shows two error in my case.
1: Warning: Global lnms shortcut not installed. lnms command must be run with full path
Fix: sudo ln -s /opt/librenms/lnms /usr/local/bin/lnms
2: Fail: No composer available, please install composer
Fix: https://getcomposer.org/
However Fix does not seem to work. But when I run validation from Cli it is showing clear. NO issue.
[librenms@NEW-SRV-UT0 ~]$ ./validate.php
LibreNMS 1.70.1-6-g9ccb70733
DB Schema 2020_11_02_164331_add_powerstate_enum_to_vminfo (191)
PHP 7.3.20
Python 3.6.8
MySQL 10.3.17-MariaDB
RRDTool 1.7.0
SNMP NET-SNMP 5.8
[OK] Composer Version: 2.0.8
It my be something with the Validation on WebUI.
Regards,
Bhargav
