Hi All
/opt/librenms $ ./validate.php
Component | Version |
LibreNMS | 1.70.1 |
DB Schema | 2020_11_02_164331_add_powerstate_enum_to_vminfo (191) |
PHP | 7.3.25 |
Python | 3.8.5 |
MySQL | 10.4.17-MariaDB-1:10.4.17+maria~focal |
RRDTool | 1.7.2 |
SNMP | NET-SNMP 5.8 |
OpenSSL |
[WARN] Global lnms shortcut not installed. lnms command must be run with full path
sudo ln -s /opt/librenms/lnms /usr/local/bin/lnms
[WARN] Log rotation not enabled, could cause disk space issues
sudo cp /opt/librenms/misc/librenms.logrotate /etc/logrotate.d/librenms
Hopefully a quick one. I have copied to weathermapper plugin to the plugins folder (containing Weathermap plugin) but it is not showing in the plugins section of the GUI. I am running Librenms in Docker. Have restarted Libre’ after the plugin was copied but no luck. I have also checked permissions and they are the same as the Weathermap plugin.
Any thoughts apprciated.
