Please find below the result of the Validate command
$ ./validate.php
Component | Version |
LibreNMS | 22.7.0-58-g83126161d |
DB Schema | 2022_07_03_1947_add_app_data (244) |
PHP | 8.1.8 |
Python | 3.6.9 |
Database | MariaDB 10.5.16-MariaDB-1:10.5.16+maria~bionic |
RRDTool | 1.7.0 |
SNMP | 5.7.3 |
[OK] Composer Version: 2.3.10
[OK]
[OK] MySQl and PHP time match
When we try to go to the Webinterface (Apache2) we get:
Whoops, looks like something went wrong. Check your librenms.log.
In the logfile I can find following error, each time I refresh the interface:
[2022-08-09T15:04:28.953391+02:00]
production.ERROR: call_user_func(): Argument #1 ($callback) must be a valid callback, non-static method
LibreNMS\Plugins\Weathermapper::menu() cannot be called statically
(View: /opt/librenms/resources/views/layouts/librenmsv1.blade.php)
{“userId”:126,“exception”:"[object] (Illuminate\View\ViewException(code: 0):
call_user_func(): Argument #1 ($callback) must be a valid callback, non-static method LibreNMS\Plugins\Weathermapper::menu() cannot be called statically
at /opt/librenms/LibreNMS/Plugins.php:189)
[previous exception] [object] (Illuminate\View\ViewException(code: 0): call_user_func(): Argument #1 ($callback) must be a valid callback, non-static method LibreNMS\Plugins\Weathermappe
r::menu() cannot be called statically (View: /opt/librenms/resources/views/layouts/librenmsv1.blade.php) at /opt/librenms/LibreNMS/Plugins.php:189)
[previous exception] [object] (TypeError(code: 0): call_user_func(): Argument #1 ($callback) must be a valid callback, non-static method LibreNMS\Plugins\Weathermapper::menu() cannot be ca
lled statically at /opt/librenms/LibreNMS/Plugins.php:189)"}
[2022-08-09T15:04:30.656062+02:00]
production.ERROR: call_user_func(): Argument #1 ($callback) must be a valid callback, non-static method LibreNMS\Plugins\Weathermapper::menu() cannot be ca
lled statically (View: /opt/librenms/resources/views/layouts/librenmsv1.blade.php) (View: /opt/librenms/resources/views/layouts/librenmsv1.blade.php) {“userId”:126,“exception”:"[object] (Ill
uminate\View\ViewException(code: 0): call_user_func(): Argument #1 ($callback) must be a valid callback, non-static method LibreNMS\Plugins\Weathermapper::menu() cannot be called statica
lly (View: /opt/librenms/resources/views/layouts/librenmsv1.blade.php) (View: /opt/librenms/resources/views/layouts/librenmsv1.blade.php) at /opt/librenms/LibreNMS/Plugins.php:189)
This looks like an incompatibility between the code and PHP 8.1
What can we do to resolve this?
Thanks in Advance.
Kurt
