Jorg
#1
Yesterday i have install LibreNMS for the first time.
It’s running on a VM with Centos 8.
And everything looks fine after i left de server.
Until today.
Webgui has a error 500.
if i do the command ./validate.php i get the folwing output:
librenms]$ ./validate.php
In ProviderRepository.php line 208:
Class ‘App\Providers\DatastoreServiceProvider’ not found
Component |
Version |
LibreNMS |
1.61 |
DB Schema |
Not Connected (0) |
PHP |
7.2.11 |
MySQL |
RRDTool |
1.7.0 |
SNMP |
NET-SNMP 5.8 |
[OK] Composer Version: 1.10.1
There is a problem with de DB connection but i have test the database with ROOT and librenms password with no problem.
The only problem i see is
is that the problem of the issue i have? And how can i fix this?
Kind regards,
Jorg
Jorg
#2
De problem is solved.
Some how i had lost de file /opt/librenms/app/Providers/DatastoreServiceProvider.php
When i make a new DatastoreServiceProvider.php.
I put this in the file:
Everything works again.
