Hello, Has anyone faced this issue after last git pull?
I got this error on the webui, tried multiple browsers with the same issue.
I have a separate lab librenms instance, update to v1.64.1-41-g62ca4ea also faced the same issue.
“Whoops, looks like something went wrong. Check your librenms.log.
Check your log for more details. (librenms.log)”
from librenms.log:
[2020-06-12 15:38:34] production.ERROR: Target class [2fa] does not exist. {“userId”:1,“exception”:"[object] (Illuminate\Contracts\Container\BindingResolutionException(code: 0): Target class [2fa] does not exist. at /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/Container.php:805)
[stacktrace]
#0 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/Container.php(681): Illuminate\Container\Container->build()
#1 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(785): Illuminate\Container\Container->resolve()
#2 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/Container.php(629): Illuminate\Foundation\Application->resolve()
#3 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(770): Illuminate\Container\Container->make()
more errors in librenms.log:
[2020-06-12 15:30:29] production.ERROR: SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ‘"’ at line 1 (SQL: SELECT * FROM devices,ports WHERE (devices.device_id = 76 AND devices.device_id = ports.device_id) AND (((ports.ifInOctets_rate*8) / ports.ifSpeed) 100) >= 90 AND ports.ifType REGEXP “ethernet” = ") (SQL: SELECT * FROM devices,ports WHERE (devices.device_id = 76 AND devices.device_id = ports.device_id) AND (((ports.ifInOctets_rate 8) / ports.ifSpeed)*100) >= 90 AND ports.ifType REGEXP “ethernet” = ")#0 /opt/librenms/LibreNMS/Alert/AlertRules.php(74): dbFetchRows(‘SELECT * FROM d…’, Array)
#1 /opt/librenms/poller.php(156): LibreNMS\Alert\AlertRules->runRules(76)
#2 {main}
