My webui loading something like 15 seconds. When I watch htop, I saw this:
https://imgur.com/wLpNQJc
Is it normal?
I got about ~200 devices.
Your image is just a blur. What is your hardware?
8 cores(2 socket, 4 cores)
21 gb ram
sas 80 gb
Please c&p the output of htop or top as text.
Did you walk through the performance tips
On https://docs.librenms.org/#Support/Performance/
top - 18:28:22 up 4 days, 4:19, 1 user, load average: 5.43, 5.59, 5.65
Tasks: 513 total, 6 running, 507 sleeping, 0 stopped, 0 zombie
%Cpu(s): 51.9 us, 13.3 sy, 0.0 ni, 32.9 id, 0.2 wa, 0.0 hi, 1.7 si, 0.0 st
KiB Mem : 22092376 total, 383736 free, 8653360 used, 13055280 buff/cache
KiB Swap: 1044476 total, 1043088 free, 1388 used. 12430600 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
2220 www-data 20 0 368660 33612 21700 S 81.0 0.2 2385:29 php-fpm7.0
4061 www-data 20 0 368576 33580 21724 S 29.0 0.2 3191:38 php-fpm7.0
2116 www-data 20 0 368572 33668 21816 R 27.5 0.2 2386:42 php-fpm7.0
10377 www-data 20 0 368572 33320 21472 S 25.0 0.2 2888:44 php-fpm7.0
26000 www-data 20 0 368632 33784 21896 S 25.0 0.2 3335:09 php-fpm7.0
1741 mysql 20 0 815024 267660 15388 S 15.0 1.2 639:14.64 mysqld
29238 librenms 20 0 1662560 686024 2848 S 12.0 3.1 235:21.52 rrdcached
29553 www-data 20 0 125752 13164 9600 R 3.0 0.1 0:00.06 rrdtool
1574 www-data 20 0 131316 6144 3200 S 2.0 0.0 12:09.99 nginx
29563 www-data 20 0 125372 12392 9336 R 2.0 0.1 0:00.04 rrdtool
29236 roma 20 0 42244 4140 3104 R 1.5 0.0 0:00.06 top
29565 www-data 20 0 125320 12204 9156 R 1.5 0.1 0:00.03 rrdtool
7 root 20 0 0 0 0 S 0.5 0.0 15:26.44 rcu_sched
23 root 20 0 0 0 0 S 0.5 0.0 20:14.50 ksoftirqd/3
43 root 20 0 0 0 0 S 0.5 0.0 16:36.14 ksoftirqd/7
948 root 20 0 270540 73196 6892 S 0.5 0.3 0:16.36 ruby
1533 root 20 0 274428 76868 7348 S 0.5 0.3 0:08.30 ruby
6034 root 20 0 274768 76372 7348 S 0.5 0.3 0:03.25 ruby
6801 root 20 0 205552 44932 6980 S 0.5 0.2 0:00.92 ruby
6831 root 20 0 227724 51152 7352 S 0.5 0.2 0:01.05 ruby
8494 root 20 0 273960 75996 6956 S 0.5 0.3 0:18.96 ruby
8615 root 20 0 274696 77224 7316 S 0.5 0.3 0:03.68 ruby
11497 root 20 0 261784 69576 7376 S 0.5 0.3 0:01.42 ruby
12303 root 20 0 274824 75772 7372 S 0.5 0.3 0:03.92 ruby
13809 root 20 0 270740 73244 6932 S 0.5 0.3 0:09.14 ruby
14057 root 20 0 270120 73280 6772 S 0.5 0.3 0:13.81 ruby
15970 root 20 0 273992 76124 6956 S 0.5 0.3 0:14.52 ruby
16477 root 20 0 274212 76724 6960 S 0.5 0.3 0:09.29 ruby
18893 root 20 0 274548 74452 7156 S 0.5 0.3 0:01.83 ruby
20489 root 20 0 273372 76368 6892 S 0.5 0.3 0:17.48 ruby
21019 root 20 0 274292 75056 7360 S 0.5 0.3 0:01.96 ruby
22004 root 20 0 270004 73388 7152 S 0.5 0.3 0:07.23 ruby
23274 root 20 0 274504 76224 7224 S 0.5 0.3 0:07.37 ruby
23969 root 20 0 274060 76256 6976 S 0.5 0.3 0:04.96 ruby
24426 root 20 0 270836 73960 6804 S 0.5 0.3 0:19.25 ruby
24837 root 20 0 0 0 0 S 0.5 0.0 0:00.25 kworker/u16:0
24954 root 20 0 273756 76036 7356 S 0.5 0.3 0:07.76 ruby
26598 root 20 0 270484 73440 6936 S 0.5 0.3 0:13.93 ruby
26814 root 20 0 272668 77168 7344 S 0.5 0.3 0:05.08 ruby
29298 root 20 0 268900 73796 7380 S 0.5 0.3 0:02.66 ruby
29569 www-data 20 0 122680 9480 8352 R 0.5 0.0 0:00.01 rrdtool
32337 root 20 0 271136 73804 6772 S 0.5 0.3 0:18.49 ruby
1 root 20 0 37828 5772 3900 S 0.0 0.0 0:18.25 systemd
2 root 20 0 0 0 0 S 0.0 0.0 0:00.04 kthreadd
3 root 20 0 0 0 0 S 0.0 0.0 23:26.01 ksoftirqd/0
5 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kworker/0:0H
8 root 20 0 0 0 0 S 0.0 0.0 0:00.00 rcu_bh
9 root rt 0 0 0 0 S 0.0 0.0 0:31.02 migration/0
10 root rt 0 0 0 0 S 0.0 0.0 0:00.86 watchdog/0
11 root rt 0 0 0 0 S 0.0 0.0 0:00.84 watchdog/1
12 root rt 0 0 0 0 S 0.0 0.0 0:32.59 migration/1
13 root 20 0 0 0 0 S 0.0 0.0 21:21.88 ksoftirqd/1
15 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kworker/1:0H
16 root rt 0 0 0 0 S 0.0 0.0 0:00.84 watchdog/2
17 root rt 0 0 0 0 S 0.0 0.0 0:32.95 migration/2
18 root 20 0 0 0 0 S 0.0 0.0 20:39.40 ksoftirqd/2
htop
29239 librenms 20 0 1615M 670M 2848 S 0.0 3.1 0:00.00 /usr/bin/rrdcached -B -F -R -w 1800 -z 1800 -t 4 -b /opt/librenms/rrd/ -j /var/lib/rrdcached/journal/ -G librenms -U librenms -p /run/rrdcached.pid -s librenms -l unix:/run/r
29240 librenms 20 0 1615M 670M 2848 S 0.0 3.1 0:29.01 /usr/bin/rrdcached -B -F -R -w 1800 -z 1800 -t 4 -b /opt/librenms/rrd/ -j /var/lib/rrdcached/journal/ -G librenms -U librenms -p /run/rrdcached.pid -s librenms -l unix:/run/r
29241 librenms 20 0 1617M 670M 2848 S 0.0 3.1 0:28.86 /usr/bin/rrdcached -B -F -R -w 1800 -z 1800 -t 4 -b /opt/librenms/rrd/ -j /var/lib/rrdcached/journal/ -G librenms -U librenms -p /run/rrdcached.pid -s librenms -l unix:/run/r
29242 librenms 20 0 1617M 670M 2848 S 0.0 3.1 0:28.85 /usr/bin/rrdcached -B -F -R -w 1800 -z 1800 -t 4 -b /opt/librenms/rrd/ -j /var/lib/rrdcached/journal/ -G librenms -U librenms -p /run/rrdcached.pid -s librenms -l unix:/run/r
29243 librenms 20 0 1615M 670M 2848 S 0.0 3.1 0:28.88 /usr/bin/rrdcached -B -F -R -w 1800 -z 1800 -t 4 -b /opt/librenms/rrd/ -j /var/lib/rrdcached/journal/ -G librenms -U librenms -p /run/rrdcached.pid -s librenms -l unix:/run/r
29244 librenms 20 0 1615M 670M 2848 S 0.0 3.1 0:00.05 /usr/bin/rrdcached -B -F -R -w 1800 -z 1800 -t 4 -b /opt/librenms/rrd/ -j /var/lib/rrdcached/journal/ -G librenms -U librenms -p /run/rrdcached.pid -s librenms -l unix:/run/r
29238 librenms 20 0 1615M 670M 2848 S 8.6 3.1 3h55:30 /usr/bin/rrdcached -B -F -R -w 1800 -z 1800 -t 4 -b /opt/librenms/rrd/ -j /var/lib/rrdcached/journal/ -G librenms -U librenms -p /run/rrdcached.pid -s librenms -l unix:/run/r
1750 mysql 20 0 795M 260M 15388 S 0.0 1.2 0:01.14 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
1751 mysql 20 0 795M 260M 15388 S 0.0 1.2 0:32.67 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
1752 mysql 20 0 795M 260M 15388 S 0.0 1.2 0:49.84 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
1753 mysql 20 0 795M 260M 15388 S 0.0 1.2 0:33.51 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
1754 mysql 20 0 795M 260M 15388 S 0.0 1.2 0:33.64 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
1755 mysql 20 0 795M 260M 15388 S 0.0 1.2 0:34.19 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
1756 mysql 20 0 795M 260M 15388 S 0.0 1.2 0:34.10 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
1757 mysql 20 0 795M 260M 15388 S 0.5 1.2 1:01.63 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
1758 mysql 20 0 795M 260M 15388 S 0.0 1.2 0:47.46 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
1759 mysql 20 0 795M 260M 15388 S 0.0 1.2 0:42.21 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
1760 mysql 20 0 795M 260M 15388 S 0.0 1.2 0:46.84 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
1761 mysql 20 0 795M 260M 15388 S 0.0 1.2 0:03.60 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
1784 mysql 20 0 795M 260M 15388 S 0.0 1.2 0:17.97 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
1785 mysql 20 0 795M 260M 15388 S 0.0 1.2 0:28.55 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
1786 mysql 20 0 795M 260M 15388 S 0.0 1.2 0:32.64 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
1787 mysql 20 0 795M 260M 15388 S 0.0 1.2 0:05.43 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
1788 mysql 20 0 795M 260M 15388 S 0.0 1.2 0:03.83 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
1789 mysql 20 0 795M 260M 15388 S 0.0 1.2 3:19.44 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
1790 mysql 20 0 795M 260M 15388 S 0.5 1.2 6:38.40 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
1791 mysql 20 0 795M 260M 15388 S 0.0 1.2 0:17.25 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
1794 mysql 20 0 795M 260M 15388 S 0.0 1.2 0:00.00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
1797 mysql 20 0 795M 260M 15388 S 0.0 1.2 0:00.00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
1799 mysql 20 0 795M 260M 15388 S 0.0 1.2 1:02.86 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
17173 mysql 20 0 795M 260M 15388 S 1.8 1.2 1h08:24 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
8570 mysql 20 0 795M 260M 15388 S 0.0 1.2 1h05:24 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
6062 mysql 20 0 795M 260M 15388 S 2.3 1.2 58:30.20 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
11603 mysql 20 0 795M 260M 15388 S 0.9 1.2 48:47.11 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
12527 mysql 20 0 795M 260M 15388 S 1.8 1.2 48:50.61 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
11619 mysql 20 0 795M 260M 15388 S 0.5 1.2 0:04.19 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
10191 mysql 20 0 795M 260M 15388 S 0.5 1.2 0:03.26 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
10193 mysql 20 0 795M 260M 15388 S 0.5 1.2 0:02.97 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
6941 mysql 20 0 795M 260M 15388 S 0.0 1.2 0:02.11 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
6951 mysql 20 0 795M 260M 15388 S 0.0 1.2 0:02.28 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
6971 mysql 20 0 795M 260M 15388 S 0.9 1.2 0:02.28 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
6873 mysql 20 0 795M 260M 15388 S 0.0 1.2 0:01.09 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
6895 mysql 20 0 795M 260M 15388 S 0.9 1.2 0:01.21 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
6905 mysql 20 0 795M 260M 15388 S 0.5 1.2 0:01.27 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
1741 mysql 20 0 795M 260M 15388 S 12.2 1.2 10h39:26 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-log-error --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/
16580 root 20 0 275M 84292 6888 S 0.0 0.4 0:00.11 /usr/bin/ruby /opt/librenms/rrd/graphs/graphs_generator_day.rb
16572 root 20 0 275M 84292 6888 S 0.0 0.4 0:20.34 /usr/bin/ruby /opt/librenms/rrd/graphs/graphs_generator_day.rb
13280 root 20 0 267M 77676 7380 S 0.0 0.4 0:00.01 /usr/bin/ruby /opt/librenms/rrd/graphs/graphs_generator_day.rb
13276 root 20 0 267M 77676 7380 S 0.5 0.4 0:03.96 /usr/bin/ruby /opt/librenms/rrd/graphs/graphs_generator_day.rb
32697 root 20 0 268M 77384 7400 S 0.0 0.4 0:00.02 /usr/bin/ruby /opt/librenms/rrd/graphs/graphs_generator_day.rb
32692 root 20 0 268M 77384 7400 S 0.0 0.4 0:05.53 /usr/bin/ruby /opt/librenms/rrd/graphs/graphs_generator_day.rb
25863 root 20 0 268M 77376 6936 S 0.0 0.4 0:00.10 /usr/bin/ruby /opt/librenms/rrd/graphs/graphs_generator_day.rb
Yes, I walk through the performance tips.
Hm,
mine looks like followed
top - 17:50:19 up 4 days, 7:33, 1 user, load average: 1,59, 0,85, 0,80
Tasks: 236 total, 1 running, 235 sleeping, 0 stopped, 0 zombie
%Cpu(s): 37,2 us, 5,6 sy, 0,0 ni, 53,2 id, 3,9 wa, 0,0 hi, 0,0 si, 0,0 st
KiB Mem : 8009192 total, 590328 free, 807956 used, 6610908 buff/cache
KiB Swap: 8257532 total, 8253684 free, 3848 used. 6564888 avail Mem
1586 mysql 20 0 3297952 331364 10148 S 264,5 4,1 3318:26 mysqld
16870 librenms 20 0 453204 21380 10468 S 1,7 0,3 0:00.17 php
16878 librenms 20 0 453204 21252 10468 S 1,3 0,3 0:00.17 php
804 root 20 0 299072 6372 4972 S 0,3 0,1 3:12.28 vmtoolsd
1589 root 20 0 1936120 5376 912 S 0,3 0,1 3:50.61 rrdcached
17132 root 20 0 162096 2440 1580 R 0,3 0,0 0:00.02 top
1 root 20 0 191396 4324 2608 S 0,0 0,1 1:22.39 systemd
2 root 20 0 0 0 0 S 0,0 0,0 0:00.13 kthreadd
3 root 20 0 0 0 0 S 0,0 0,0 0:10.20 ksoftirqd/0
5 root 0 -20 0 0 0 S 0,0 0,0 0:00.00 kworker/0:0H
7 root rt 0 0 0 0 S 0,0 0,0 0:05.45 migration/0
8 root 20 0 0 0 0 S 0,0 0,0 0:00.00 rcu_bh
9 root 20 0 0 0 0 S 0,0 0,0 0:59.11 rcu_sched
10 root 0 -20 0 0 0 S 0,0 0,0 0:00.00 lru-add-drain
11 root rt 0 0 0 0 S 0,0 0,0 0:01.69 watchdog/0
12 root rt 0 0 0 0 S 0,0 0,0 0:01.30 watchdog/1
13 root rt 0 0 0 0 S 0,0 0,0 0:06.94 migration/1
14 root 20 0 0 0 0 S 0,0 0,0 0:12.54 ksoftirqd/1
16 root 0 -20 0 0 0 S 0,0 0,0 0:00.00 kworker/1:0H
17 root rt 0 0 0 0 S 0,0 0,0 0:01.04 watchdog/2
18 root rt 0 0 0 0 S 0,0 0,0 0:08.44 migration/2
19 root 20 0 0 0 0 S 0,0 0,0 0:10.70 ksoftirqd/2
21 root 0 -20 0 0 0 S 0,0 0,0 0:00.00 kworker/2:0H
22 root rt 0 0 0 0 S 0,0 0,0 0:01.72 watchdog/3
23 root rt 0 0 0 0 S 0,0 0,0 0:06.74 migration/3
24 root 20 0 0 0 0 S 0,0 0,0 0:10.94 ksoftirqd/3
26 root 0 -20 0 0 0 S 0,0 0,0 0:00.00 kworker/3:0H
Similar hardware.
- 8 Cores (Intel® Xeon® CPU [email protected])
- 8GB RAM
- 500GB SAS (RAID 10)
But for me there are a lot of php-fpm and ruby processes running.
What about the disk I/O?
Is it a VM?
Yes, vm in a proxmox ve.
php-fpm is for your website, what is going on? Are you running daily.sh? Perhaps one of your tables has grown to massive size if you aren’t doing daily maintenance.
Yes, I run daily.sh, here is my cron:
33 */6 * * * librenms /opt/librenms/discovery.php -h all >> /dev/null 2>&1
*/5 * * * * librenms /opt/librenms/cronic /opt/librenms/poller-wrapper.py 8
15 0 * * * librenms /opt/librenms/daily.sh >> /dev/null 2>&1
* * * * * librenms /opt/librenms/alerts.php >> /dev/null 2>&1
@murrant but is it normal that there are that many processes of php-fpm?
Abs the load?!
Run ./validate.php
and pastebin the output (fix anything is reports)
LibreNMS | 1.40-38-ge151aa9
DB Schema | 252
PHP | 7.0.30-0ubuntu0.16.04.1
MySQL | 10.0.34-MariaDB-0ubuntu0.16.04.1
RRDTool | 1.5.5
SNMP | NET-SNMP 5.7.3
[OK] Composer Version: 1.6.5
Maybe try going through the performance doc.
Ok, will try it again, maybe I do something wrong first time.
