Is it possible to add Widget on the dashboard for choosing weathermaps?
Yes,
Use the Image widget and paste in the Image URL and Target URL. It would look something like this.
What do you mean by generic?So in the widget should I choose Graphs? and then there are a lot of options listed
Works, just chose image widget
Yes the image widget, sorry idk why I said generic.
