1.60-56-g40cac40ae issue
It seems that this version breaks something.
LibreNMS 1.60-56-g40cac40ae
DB Schema 2020_02_10_223323_create_alert_location_map_table (159)
PHP 7.2.24-0ubuntu0.18.04.1
MySQL 5.7.28-0ubuntu0.18.04.4
RRDTool 1.7.0
SNMP NET-SNMP 5.7.3
[OK] Composer Version: 1.9.3
Modified Files:
html/js/lang/de.js
html/js/lang/en.js
html/js/lang/fr.js
html/js/lang/ru.js
html/js/lang/uk.js
html/js/lang/zh-TW.js
A ./scripts/github-remove -d essentially fixes the ./validate.php, but rerunning ./daily.sh re-introduces the same error… or is it me ?
TIA
Hi zoeloe,
to solve the issue just, remove the following files:
html/js/lang/de.js
html/js/lang/en.js
html/js/lang/fr.js
html/js/lang/ru.js
html/js/lang/uk.js
and then run ./daily.sh again
Language files will be regenerated automatically.
Not sure what’s happening here, but here’s the attempt as you suggested, but IMHO there is still something wrong:
(note: there is a .gitigonore file in the dir httml/js/lang, containing:
Ignore everything in this directory
Except this file
!.gitignore
/opt/librenms$ ./validate.php
RRDTool 1.7.0
SNMP NET-SNMP 5.7.3
Modified Files:
html/js/lang/de.js
html/js/lang/en.js
html/js/lang/fr.js
html/js/lang/ru.js
html/js/lang/uk.js
[email protected]:/opt/librenms$ ./daily.sh
Updating Composer packages OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
RRDTool 1.7.0
SNMP NET-SNMP 5.7.3
Modified Files:
html/js/lang/de.js
html/js/lang/en.js
html/js/lang/fr.js
html/js/lang/ru.js
html/js/lang/uk.js
[email protected]:/opt/librenms$ ls -al html/js/lang/
total 380
drwxrwxr-x 2 librenms librenms 4096 Feb 22 13:32 .
drwxr-xr-x 6 librenms librenms 4096 Dec 31 00:15 …
-rw-rw-r-- 1 librenms librenms 71 Feb 22 00:45 .gitignore
-rw-rw-r-- 1 librenms librenms 76536 Feb 22 13:32 de.js
-rw-rw-r-- 1 librenms librenms 71449 Feb 22 13:32 en.js
-rw-rw-r-- 1 librenms librenms 76937 Feb 22 13:32 fr.js
-rw-rw-r-- 1 librenms librenms 28297 Feb 22 13:32 ru.js
-rw-rw-r-- 1 librenms librenms 40078 Feb 22 13:32 uk.js
-rw-rw-r-- 1 librenms librenms 74024 Feb 22 13:32 zh-TW.js
[email protected]:/opt/librenms$ ./scripts/github-remove -d
Are you sure you want to delete all modified and untracked files? [y/N] y
RRDTool 1.7.0
SNMP NET-SNMP 5.7.3
Cleaning up DB OK
[email protected]:/opt/librenms$ ./validate.php
RRDTool 1.7.0
SNMP NET-SNMP 5.7.3
Modified Files:
html/js/lang/de.js
html/js/lang/en.js
html/js/lang/fr.js
html/js/lang/ru.js
html/js/lang/uk.js
the .gitignore in html/js/lang/ is correct
so delete following files:
html/js/lang/de.js
html/js/lang/en.js
html/js/lang/fr.js
html/js/lang/ru.js
html/js/lang/uk.js
Language files will be regenerated automatically, on update
Thats why a gitignore is in
I’m sure your instructions would function under normal circumstances, but here goes a next attempt:
[email protected]:/opt/librenms/html/js/lang$ ls -al
total 380
drwxrwxr-x 2 librenms librenms 4096 Feb 22 13:33 .
-rw-rw-r-- 1 librenms librenms 76536 Feb 22 13:34 de.js
-rw-rw-r-- 1 librenms librenms 71449 Feb 22 13:34 en.js
-rw-rw-r-- 1 librenms librenms 76937 Feb 22 13:34 fr.js
-rw-rw-r-- 1 librenms librenms 28297 Feb 22 13:34 ru.js
-rw-rw-r-- 1 librenms librenms 40078 Feb 22 13:34 uk.js
-rw-rw-r-- 1 librenms librenms 74024 Feb 22 13:34 zh-TW.js
[email protected]:/opt/librenms/html/js/lang$ rm *.js
total 12
drwxrwxr-x 2 librenms librenms 4096 Feb 22 15:27 .
FIles are deleted as per good old “rm”:
[email protected]:/opt/librenms/html/js/lang$ cd /opt/librenms/
RRDTool 1.7.0
SNMP NET-SNMP 5.7.3
Modified Files:
html/js/lang/de.js
html/js/lang/en.js
html/js/lang/fr.js
html/js/lang/ru.js
html/js/lang/uk.js
OK, let’s try the ./daily.sh now:
[email protected]:/opt/librenms$ pwd
/opt/librenms
Cleaning up DB OK
total 380
drwxrwxr-x 2 librenms librenms 4096 Feb 22 15:30 .
-rw-rw-r-- 1 librenms librenms 76536 Feb 22 15:30 de.js
-rw-rw-r-- 1 librenms librenms 71449 Feb 22 15:30 en.js
-rw-rw-r-- 1 librenms librenms 76937 Feb 22 15:30 fr.js
-rw-rw-r-- 1 librenms librenms 28297 Feb 22 15:30 ru.js
-rw-rw-r-- 1 librenms librenms 40078 Feb 22 15:30 uk.js
-rw-rw-r-- 1 librenms librenms 74024 Feb 22 15:30 zh-TW.js
RRDTool 1.7.0
SNMP NET-SNMP 5.7.3
Modified Files:
html/js/lang/de.js
html/js/lang/en.js
html/js/lang/fr.js
html/js/lang/ru.js
html/js/lang/uk.js
Still there, regenerated…
tested also a “rm” and a ./daily.sh … files are there again. So validate.php isn’t happy about it.
Doesn’t really break anything IFAIK, but still wanted to report this for code cleanup puroposes.
TIA
The problem with the listed files in comming with validate.php will be solved as soon as possible.
As long as daily.sh runs without problems, updating issue is solved first
Great, knowing that there was a trivial non-breaking bug !
Thanks for the explanation and followup. My 2 cents.
8a2ce01dc still contains the anomaly.
26 Feb:
trying a manual ./daily.sh, and this says that the locally modded files: html/js/lang/.js would be overwritten by the merge.
So a rm html/js/lang/
*.js
and a succesfull ./daily.sh make ./validate.php happy (version g6d22a885a).
Issue closed I guess. Thanks for the assistance.
