What is the best way to do a 1 min poller for a specific devices rather than everything? I Just need to monitor a specific switch for a few days.
Thank You
You can’t without hacking round
@laf OK Shucks, So when I manually walk it is it not being graphed? I was thinking just manually add the script into cron like poller.php -h ip address into cron or manually run it when needed. Will something like that work?
That could work, you’ll get duplicate updates on the overlap with the 5 min poller but rrd data will just be discarded.
