Hi, first time LibreNMS user. I am not very efficient in Linux nor LibreNMS. I managed to set up 1 Minute polling and confirmed that it works via /logs/librenms.log
Unfortunately I cannot seem to get the 1 minute graph updates to work. They still step in 5min intervals.
Component |
Version |
LibreNMS |
1.65.1 |
DB Schema |
2020_06_23_00522_alter_availability_perc_column (170) |
PHP |
7.2.24-0ubuntu0.18.04.4 |
Python |
3.6.9 |
MySQL |
10.1.44-MariaDB-0ubuntu0.18.04.1 |
RRDTool |
1.7.0 |
SNMP |
NET-SNMP 5.7.3 |
[OK] Composer Version: 1.10.9
Modified Files:
scripts/rrdstep.php
I used the rrdstep.php config from the link feature: Added rrd step conversion script by laf · Pull Request #6081 · librenms/librenms · GitHub, which is why I am assuming the warning of modified files comes up. I did run the normal rrd file for 20min as well.
rrdtool graph /tmp/jGPXRfuSQYA7H4Ab --alt-autoscale-max --rigid -E --start 1595244600 --end 1595246400 --width 1728 --height 312 -c BACK#EEEEEE00 -c SHADEA#EEEEEE00 -c SHADEB#EEEEEE00 -c CANVAS#FFFFFF00 -c GRID#a5a5a5 -c MGRID#FF9999 -c FRAME#5e5e5e -c ARROW#5e5e5e -R normal -c FONT#000000 --font LEGEND:8:DejaVuSansMono --font AXIS:7:DejaVuSansMono --font-render-mode normal DEF:outoctets=10.19.255.254/port-id3.rrd:OUTOCTETS:AVERAGE DEF:inoctets=10.19.255.254/port-id3.rrd:INOCTETS:AVERAGE DEF:outoctets_max=10.19.255.254/port-id3.rrd:OUTOCTETS:MAX DEF:inoctets_max=10.19.255.254/port-id3.rrd:INOCTETS:MAX CDEF:octets=inoctets,outoctets,+ CDEF:doutoctets=outoctets,-1,* CDEF:outbits=outoctets,8,* CDEF:outbits_max=outoctets_max,8,* CDEF:doutoctets_max=outoctets_max,-1,* CDEF:doutbits=doutoctets,8,* CDEF:doutbits_max=doutoctets_max,8,* CDEF:inbits=inoctets,8,* CDEF:inbits_max=inoctets_max,8,* VDEF:totin=inoctets,TOTAL VDEF:totout=outoctets,TOTAL VDEF:tot=octets,TOTAL CDEF:dpercentile_outn=doutbits,-1,* VDEF:dpercentile_outnp=dpercentile_outn,95,PERCENT CDEF:dpercentile_outnpn=doutbits,doutbits,-,dpercentile_outnp,-1,,+ VDEF:dpercentile_out=dpercentile_outnpn,FIRST VDEF:percentile_in=inbits,95,PERCENT VDEF:percentile_out=outbits,95,PERCENT COMMENT:‘bps Now Ave Max 95th %\n’ AREA:inbits_max#D7FFC7: AREA:inbits#90B040: LINE:inbits#608720:‘In ’ GPRINT:inbits:LAST:%6.2lf%s GPRINT:inbits:AVERAGE:%6.2lf%s GPRINT:inbits_max:MAX:%6.2lf%s GPRINT:percentile_in:%6.2lf%s\n AREA:doutbits_max#E0E0FF: AREA:doutbits#8080C0: LINE:doutbits#606090:‘Out’ GPRINT:outbits:LAST:%6.2lf%s GPRINT:outbits:AVERAGE:%6.2lf%s GPRINT:outbits_max:MAX:%6.2lf%s GPRINT:percentile_out:%6.2lf%s\n GPRINT:tot:‘Total %6.2lf%sB’ GPRINT:totin:’(In %6.2lf%sB’ GPRINT:totout:‘Out %6.2lf%sB)\l’ LINE1:percentile_in#aa0000 LINE1:dpercentile_out#aa0000 VDEF:islope=inbits_max,LSLSLOPE VDEF:icons=inbits_max,LSLINT CDEF:ilsl=inbits_max,POP,islope,COUNT,,icons,+ LINE2:ilsl#44aa55:‘In Linear Prediction\n’:dashes=8 VDEF:oslope=doutbits_max,LSLSLOPE VDEF:ocons=doutbits_max,LSLINT CDEF:olsl=doutbits_max,POP,oslope,COUNT,*,ocons,+ LINE2:olsl#4400dd:‘Out Linear Prediction\n’:dashes=8 --daemon unix:/var/run/rrdcached/rrdcached.sock
RRDTool Output
1809x437
OK u:0.24 s:0.02 r:0.26
Any assistance would be appreciated.
