We have set up 1 minute polling on and for some reason we can see drops in the graphs. Just cant seem to pin down why the graphs are not showing the data all the time. Here is my current poller.
Just one device or all devices?
Likely the device’s snmp service can’t keep up. Check the performance docs for info. One way you may be able to fix that is to disable polling modules for problematic devices.
All devices.
Does not seem to matter what the device is at this point. I am using Cisco and ALE along with Mikrotik routers.
Murrant
Any thoughts?
You need to troubleshoot more.
I am new to using this software. Not sure were to start looking that is why i put the post here so see if anyone can point me in the direction i need.
