21.2.0
(2021-02-16)
A big thank you to the following 18 contributors this last month:
- murrant (9)
- Jellyfrog (8)
- PipoCanaja (1)
- hanserasmus (1)
- nightcore500 (1)
- simmonmt (1)
- SourceDoctor (1)
- dejantep (1)
- TridTech (1)
- Showfom (1)
- jasoncheng7115 (1)
- nkringle (1)
- dependabot (1)
- Negatifff (1)
- Cupidazul (1)
- paddy01 (1)
- Torch09 (1)
- bofh80 (1)
- Jellyfrog (13)
- murrant (12)
- SourceDoctor (5)
Feature
- GPS coordinates from device (#12521) - murrant
- Show Alert Count on Widget (#12503) - SourceDoctor
- Add Service Templates (#12107) - bofh80
Security
Device
- VRP - Filter invalid temperature data 0x7fffffff (#12537) - PipoCanaja
- Rittal CMC III low warn limit and CAN bus current (#12513) - nightcore500
- Add TrueNAS temperature (#12506) - simmonmt
- Update deltaups.yaml definition (#12497) - TridTech
- Fixes incorrect device overlay graph type for poweralert 12 devices (#12491) - nkringle
- Socomecpdu support (#12481) - Negatifff
- Add support for SCS KS air-conditioning Devices (#12360) - Torch09
Webui
Authentication
Applications
Discovery
Bug
- Better handling of invalid notification dates (#12523) - murrant
- Fix invalid dates in the database (#12512) - Jellyfrog
- Fix Fast Ping alerts always running (#12510) - murrant
- Fix Fast Ping (#12509) - murrant
- Network map fix Css/img (#12498) - dejantep
- Correct check for SNMPv3 SHA-192/256 compability (#12494) - Jellyfrog
Cleanup
Documentation
- Update transports docs (#12518) - hanserasmus
- Correct rrdcached.sock location on doc (#12496) - Showfom
Translation
- Updated Traditional Chinese Translation (#12493) - jasoncheng7115
