21.3.0
(2021-03-20)
A big thank you to the following 27 contributors this last month:
- murrant (14)
- Jellyfrog (12)
- PipoCanaja (6)
- SourceDoctor (4)
- si458 (2)
- Cormoran96 (2)
- miff2000 (2)
- mpikzink (1)
- rasssta (1)
- dependabot (1)
- Chewie9999 (1)
- bennet-esyoil (1)
- rkojedzinszky (1)
- bofh80 (1)
- WillIrvine (1)
- pbaldovi (1)
- h-barnhart (1)
- waddles (1)
- scamp (1)
- aarchijs (1)
- yrebrac (1)
- Serphentas (1)
- theochita (1)
- Schouwenburg (1)
- neg2led (1)
- bakerds (1)
- CirnoT (1)
- Jellyfrog (28)
- murrant (17)
- PipoCanaja (8)
- SourceDoctor (8)
- f0o (1)
- crazy-max (1)
- yrebrac (1)
Feature
Device
- Add identification for Edgeswitch 8XP (#12622) - si458
- Add more printer data (#12617) - Jellyfrog
- Update hpe-ilo.yaml (#12612) - rasssta
- Fix AOS 7 sensors (#12599) - murrant
- Collect BIOS version for IBMC (#12586) - PipoCanaja
- Added support for siteboss571 + new tests (#12568) - WillIrvine
- VRP - Huawei Wifi Controllers and routers 3G/4G update (#12565) - PipoCanaja
- F5 realservers (node_name) display (#12553) - PipoCanaja
- Add BGP discovery and polling for Dell OS10 devices (#12549) - waddles
- Update support for ServersCheck (#12546) - Jellyfrog
- Add support for Edge-Core ECS4100 series devices (#12530) - scamp
- Adding Cisco ME1200 support (#12527) - aarchijs
- Cisco enhanced cellular (#12463) - Schouwenburg
- Support newer SyncServer (#12423) - neg2led
- Added alarm detection and optical PMs for Waveserver Ai (#12380) - bakerds
Webui
- Fix services availability-map link (#12632) - si458
- Add css text center (#12608) - Cormoran96
- Sort Type List in Eventlog Pages (#12572) - SourceDoctor
- Spanning Tree Link in Eventlog (#12571) - SourceDoctor
- Notifications : display sensor state textual value (#12554) - PipoCanaja
- GUI - Fix the detailed access point view (#12543) - PipoCanaja
- Add button to show verbose alert details in the alert, alert-log webui (#12484) - theochita
Snmp Traps
- Fixed typo jnxPowerSupplyOK (#12556) - h-barnhart
Applications
- Add application powermon (#12500) - yrebrac
- Chrony support (#12488) - Serphentas
- Docker stats app (#12358) - Cormoran96
Alerting
Discovery
- DynamicDiscovery - Guess num_oid if not provided in YAML file (#12570) - PipoCanaja
- Fix location for devices with broken snmp (#12544) - murrant
Oxidized
Bug
- Bugfix for no sockets on Unix Agents (#12637) - mpikzink
- Fix Service Templates Dynamic (#12626) - murrant
- Service templates - fix rules (#12587) - bofh80
- Fix vminfo invalid power state in migration (#12567) - murrant
- Add missing Power states (#12559) - Jellyfrog
- PHP 8 fixes (#12528) - murrant
Refactor
Documentation
- Update Agent-Setup.md with systemd instructions on how to restrict on which NIC the agent listens. (#12601) - Chewie9999
- Broken link on fast-polling page (#12595) - bennet-esyoil
- Fix bullet points (#12574) - miff2000
- Fix the bullet point rendering (#12560) - miff2000
Tests
Misc
- Set correct min database version (#12606) - Jellyfrog
- Simplify process reaping (#12593) - rkojedzinszky
- Fix broken tests (#12588) - Jellyfrog
- Add minimum database version check (#12581) - Jellyfrog
- Global Settings - SNMP Timeout (#12579) - SourceDoctor
- Improved rrdtool version validation (#12539) - murrant
- Use DNS Location Record for Location (#12409) - SourceDoctor
Dependencies
- Bump elliptic from 6.5.3 to 6.5.4 (#12602) - dependabot
