LibreNMS version 21.6.0 has been released!
We thank each and every of the 23 different contributors to LibreNMS this month. Make sure you thank them for their time and effort
If you would like help with LibreNMS in any way, let us know in Discord .
Reminder that the MySQL supported versions has been updated due to upstream support ending. (Min 5.7.7/10.2.2). This month saw some database changes that will prevent Web UI access if your database is not up-to-date. Dan Baker has laid out the update process for CentOS 7 users here
Notable features this release include:
- cisco-sla module rename slas and Juniper Support added. It should be much easier to add SLA support for other OS now. RTT was added to the database for alerting as well
- IS-IS polling in the router module using the standard ISIS-MIB
- 21 devices have new or updated support
- mpikzink Continues to work on better sub-directory support.
- Many bug fixes
Thanks to Jellyfrog and PipoCanaja for getting PRs merged this month as I (murrant) have been busy!
There are some great changes pending for next month.
You can checkout the Pull Requests on GitHub and give feedback on them to help them get merged.
As always, Happy Monitoring.
