22.12.0
(2022-12-28)
A big thank you to the following 21 contributors this last month:
- murrant (10)
- electrocret (4)
- bnerickson (4)
- peelman (2)
- bonzo81 (2)
- gdepeyrot (2)
- bogdanrotariu (2)
- TheMysteriousX (2)
- LoveSkylark (1)
- fcqpl (1)
- angeletdemon (1)
- alchemyx (1)
- rinsekloek (1)
- SantiagoSilvaZ (1)
- dependabot (1)
- gewuerfelt (1)
- tuxgasy (1)
- hugalafutro (1)
- nightcore500 (1)
- mrwold (1)
- rhinoau (1)
- Jellyfrog (15)
- murrant (14)
- PipoCanaja (3)
- ottorei (3)
- SeeMyPing (1)
Feature
Device
- Additional sensors (#14756) - peelman
- Update fs-nmu.inc.php (#14702) - gewuerfelt
- Support Huawei SMU02B (#14673) - nightcore500
- Use ācounterā RRD type for some TrueNAS sensors (#14670) - TheMysteriousX
- Device - Add support for āSmartpack Rā (#14665) - mrwold
Webui
- Fix port speed setting feedback (#14743) - murrant
- Fix Cimc on Overview (#14727) - electrocret
- Fix check rrd file exists with remote rrdcached (#14690) - tuxgasy
Alerting
- Add -I flag to Traceroute cmd (#14667) - electrocret
Graphs
- Fix graph output base64 (#14701) - murrant
- Fix some graphs not respecting device display name (#14684) - murrant
- Adding Average into graphs (#14679) - bogdanrotariu
Applications
- Update Nvidia application - values in wrong charts (#14736) - fcqpl
- Removing max polling restriction for wireguard traffic RRD data (#14710) - bnerickson
Api
- Fix for RIPE NCC API Tools (#14757) - LoveSkylark
- API list_devices update with sysName, location_id and type (#14731) - bonzo81
Polling
Refactor
Documentation
- Install updates for Rocky8 (#14722) - angeletdemon
- Updating certificate script documentation (#14721) - bnerickson
- Update Docker.md with proper path to unzipped files (#14717) - alchemyx
- Fix typo: purge-port.php file name (#14712) - SantiagoSilvaZ
- Alert template example uses incorrect variable (#14683) - electrocret
- Correct squid snmpd.conf proxy host syntax (#14678) - hugalafutro
Tests
- Adding certificate application tests (#14708) - bnerickson
Misc
- Option discovery_remove_domain to strip domainname from FQDN (#14716) - rinsekloek
- Search devices also in display (#14714) - gdepeyrot
- Add MAC OUI caching when code updates are disabled (#14713) - gdepeyrot
- Adding sample alert for systemd application (#14711) - bnerickson
- Polling poller debug (#14691) - electrocret
- Prevent spurious MAC changes on multi-interface devices (#14671) - TheMysteriousX
- Added Moxa switching ifAlias/portName mapping (#14633) - rhinoau
Internal Features
- Number Casting allow preceding space (#14699) - murrant
- Improve SnmpResponse value() (#14605) - murrant
Mibs
- Add CISCO-ENTITY-ALARM-MIB file (#14754) - bonzo81
- Update Nokia MIBs to release R22.2 (#14734) - peelman
Dependencies
- Update PHP dependencies (fix dependencies on PHP 8.2) (#14759) - murrant
- Bump qs and express (#14705) - dependabot
