A big thank you to the following 22 contributors this last month:
- Jellyfrog (22)
- murrant (11)
- PipoCanaja (7)
- Npeca75 (7)
- ilGino (6)
- SantiagoSilvaZ (4)
- laf (3)
- h-barnhart (2)
- aztec102 (2)
- Fehler12 (1)
- JKJameson (1)
- jepke (1)
- sGoico (1)
- dorkmatt (1)
- SourceDoctor (1)
- si458 (1)
- dfitton (1)
- Martin22 (1)
- fsmeets (1)
- dependabot (1)
- knpo (1)
- guipoletto (1)
- Jellyfrog (35)
- murrant (16)
- laf (14)
- PipoCanaja (10)
- ottorei (6)
- SourceDoctor (5)
- kkrumm1 (1)
Feature
Security
- Hide community and make it XSS safer (#13783) - PipoCanaja
- Moved some pages to be within admin route (#13782) - laf
- XSS fix (#13780),(#13778),(#13776),(#13775) - PipoCanaja
- Bump follow-redirects package from 1.14.7 to 1.14.8 (#13774) - dependabot
Device
- Support for Terra sdi410c / sdi480 devices (#13759) - Npeca75
- Added BER to Racom Ray and Ray3 (#13758) - Martin22
- Added system temperature support including state for Extreme VSP 4900 devices (#13743) - laf
- Added ipv6 route discovery for Mikrotik devices (#13737) - Npeca75
- Fixed airos temp in 8.7.7 for ubnt devices (#13731) - murrant
- Added sensors to ZXA OS (#13724) - aztec102
- Added support for Volius OS (#13723) - aztec102
- Updated DDM MIBs for Jetstream OS (#13715) - Npeca75
- Added support for Ubiquiti Airfiber60 devices (#13680) - jepke
- Fixed Temperature Sensor for AirOS 8.7.4+ (#13655) - JKJameson
- Added support for Lenovo think station devices (#13617) - Fehler12
- Added sensors for huawei vrp devices (#13352) - guipoletto
Webui
- Rewrite includes/html/pages/device/health.inc.php (#13777) - Npeca75
- Various fixes for STP (#13773) - PipoCanaja
- Added missing icons for progressive web app (#13771) - murrant
- Show selected selection option on graphs page in Mono theme (#13765) - SantiagoSilvaZ
- Show selected option of devices-graphs-select in Mono theme (#13752) - SantiagoSilvaZ
- Upgrade to font awesome 6 (#13760) - Jellyfrog
- Upgrade to font awesome 5 (#13754) - Jellyfrog
- Update dark.css to improve visibility (#13749) - dfitton
- Removing colon symbol from multiple dialogs (#13742) - ilGino
- Added the word Actions in the header of the oxidized-nodes table (#13741) - SantiagoSilvaZ
- Updated icons of links pointing to Health pages (#13729) - ilGino
- Updated to a more consistent Fontawesome icon for the Export to PDF (#13713) - ilGino
- Removing the colon symbol to the right of a control labels (#13704),(#13705) - ilGino
- Update to tailwind 3 (#13695) - Jellyfrog
Alerting
Snmp Traps
- Added SNMP Traps for Brocade login traps (#13770) - h-barnhart
- Added SNMP Traps for APC Overload Traps (#13726) - h-barnhart
Discovery
Bug
- Only try contexts in STP for Cisco devices (#13767) - murrant
- Fix settings array initial value (#13755) - Jellyfrog
- Use better filesystem functions to delete host rrd dir (#13735) - Jellyfrog
- Device:poll log poll complete (#13733) - murrant
- Fixed < 0 exception in ports poller (#13732) - murrant
- Fixed ups-nut check (#13722) - Jellyfrog
- Changed fping hardcoded binary to user defined fping (#13720) - sGoico
Refactor
- Oxidized reload called on Device update and remove (#13730) - murrant
- Stp module rewrite (#13570) - murrant
Cleanup
- Dropped dbfetch from discovery/sensors for pbn devices (#13789) - Npeca75
- Dropped dbfetch from discovery/sensors for junos devices (#13784) - Npeca75
- Removed contrib directory (#13727) - murrant
- Removed old vendor fix (#13717) - Jellyfrog
- Replace Requests library with HTTP Client (#13689) - Jellyfrog
- Use built in method to render a string with Blade (#13688) - Jellyfrog
Documentation
- Simple docs tweaking (#13792) - Jellyfrog
- Update Switching API doc to fix link (#13786) - knpo
- Rename DHCP Stats to ISC DHCP Stats (#13756) - SourceDoctor
- Update Install-LibreNMS.md to include pip3 install (#13746) - si458
- validate-config-icon better positioning in the text (#13744) - SantiagoSilvaZ
- Updated Debian install docs to include pip3 install (#13721) - dorkmatt
- Full rework of documentation for better nav, cleanup and fixes (#13709) - Jellyfrog
Tests
- Bump test timeout to 2 hours (#13769) - Jellyfrog
- Speed up tests by reducing snmp timeout (#13725) - murrant
- Lnms dev:check add --os-modules-only option (#13700) - murrant
Misc
- Set default DB_TEST_PORT in database config (#13793) - Jellyfrog
- Fixed links to connected devices in old style maps (#13762) - fsmeets
- Updated Top Devices widget to include filtering on ifOperStatus (#13748) - Npeca75
- Correct prefix for “kilo” should be small k, not capital K (#13714) - ilGino
- Remove old composer preinstall script (#13712) - Jellyfrog
- Improve Proxy::shouldBeUsed (#13702) - Jellyfrog
- Use commit date to compare pull requestes (#13701) - Jellyfrog
