22.3.0
(2022-03-17)
A big thank you to the following 22 contributors this last month:
- murrant (7)
- Jellyfrog (5)
- bonzo81 (4)
- laf (3)
- PipoCanaja (2)
- charlyforot (2)
- geg347 (2)
- westerterp (2)
- ospfbgp (1)
- MrXermon (1)
- pandalion98 (1)
- eskyuu (1)
- josh-silvas (1)
- martinberg (1)
- lpailhas (1)
- hanserasmus (1)
- si458 (1)
- SantiagoSilvaZ (1)
- LTangaF (1)
- dlangille (1)
- Npeca75 (1)
- woidi (1)
- Jellyfrog (19)
- murrant (10)
- laf (8)
- SourceDoctor (3)
- ottorei (1)
- bboy8012 (1)
- PipoCanaja (1)
Feature
- Device_add support display field (#13846) - murrant
- Add configuration support for IPMIv2 Kg key (#13845) - pandalion98
- Display Name in availability map (#13841) - murrant
- Implement OAuth and SAML2 support (#13764) - Jellyfrog
Security
Device
- Add support for VOSS 8.6 (#13857) - ospfbgp
- Device - HWG-WLD version 2 support (#13849) - PipoCanaja
- Fix an issue with the APC current discovery (#13837) - eskyuu
- Add VS state for Gaia (#13831) - martinberg
- [new OS] Alpine OptoElectronics TDCM-EDFA support (#13825) - charlyforot
- Fix db delete on cisco-vrf-lite discovery (#13823) - lpailhas
- Add rocky linux OS identification (#13815) - hanserasmus
- Detect truenas scale (#13812) - si458
- [comware] dropped dbfetch from discovery/sensors (#13796) - Npeca75
- Correct divisor in discovery definition vertiv-pdu.yaml (#13768) - woidi
Webui
- Fix class error name prevents to show BER graph (#13833) - charlyforot
- Fixed displaying hostname in create bill when port is passed (#13830) - laf
- Fix Oxidized Config tab showing when Device OS or Device Type is disabled (#13809) - westerterp
- Position the buttons in the center on user preferences page (#13802) - SantiagoSilvaZ
- Add usage hints for Display Name placeholder usage (#13801) - LTangaF
- Fix second menu bar in Apps screens (#13800) - westerterp
- WebUI - Search results for ports (#13787) - PipoCanaja
Alerting
- Newer versions of Jira use HTTP code 201 fore created issues (#13852) - MrXermon
- Add extra dynamic values alerttransport alertmanager (#13828) - geg347
- Add generic PSU status failed alert rule template (#13821) - geg347
Snmp Traps
- Add APC SmartAvrReducing trap handlers (#13839) - bonzo81
- Add APC upsOnBattery & powerRestored trap handler (#13836) - bonzo81
- Add OspfTxRetransmit Trap Handler (#13824) - bonzo81
- Cisco Mac address violation trap handler (#13811) - bonzo81
Api
- Adds API call to update port notes on devices. (#13834) - josh-silvas
Bug
- Rewrite agent packages parsing code (#13840) - murrant
- Fix snmpv3 context when empty SnmpQuery (#13832) - murrant
- Regression fix from b6a8b602b891d9eb8633f62632c17bdc559cd620 (#13819) - Jellyfrog
- Fix PHPStan Deprecated test (#13794) - Jellyfrog
