22.5.0
(2022-05-21)
A big thank you to the following 23 contributors this last month:
- murrant (7)
- VVelox (6)
- slimey99uk (2)
- dependabot (2)
- Npeca75 (2)
- nox-x (1)
- nsn-amagruder (1)
- mkuurstra (1)
- booth-f (1)
- sajiby3k (1)
- skandragon (1)
- Martin22 (1)
- twelch24 (1)
- ppasserini (1)
- bl3nd3r (1)
- SantiagoSilvaZ (1)
- Jimmy-Cl (1)
- lfkeitel (1)
- steffann (1)
- micko (1)
- IVI053 (1)
- pfromme25 (1)
- mzacchi (1)
Feature
- Allow unordered OIDs (global and per-os) (#13923) - murrant
- Added --ping-only to snmp-scan.py (#13810) - IVI053
Device
- Add Cisco Business Wirless to ciscowlc.yaml (#13984) - nsn-amagruder
- Add Eaton SC200 OS model (#13978) - slimey99uk
- Fortigate LTE sensor addition (#13977) - slimey99uk
- Added BKE power supply support. (#13972) - Martin22
- Don’t use bulk-walk for PrimeKey Appliances (#13958) - bl3nd3r
- Fix avtech12e sensors (#13943) - lfkeitel
- [mikrotik] fixed RouterOS ipv4/ipv6 routes (#13902) - Npeca75
- Netscaler new counter metrics (#13323) - mzacchi
Webui
- Update dark mode to fix BGP and Peering page (#13951) - Jimmy-Cl
- Fix snmp.timeout setting via Web UI (#13937) - murrant
Alerting
Graphs
Applications
- Remove alert keys from component for Suricata (#13959) - VVelox
- Fix a few issues with variable names for Suricata (#13956) - VVelox
- Scripts/json-app-tool.php JSON generation fix and add -S for SNMP extend name (#13948) - VVelox
- Add Suricata monitoring (#13942) - VVelox
Discovery
Oxidized
Authentication
- Auth_ldap_skip_group_check when ldap_compare is not supported (#13926) - micko
- Add LDAP bind and userlist filter support to ldap-authorization (#13788) - pfromme25
Bug
- Inconsistency in ldap starttls config parameter (#13987) - nox-x
- Fix version check error (#13981) - murrant
- Use full sudo path (#13975) - skandragon
- Fix IPv6 in service check host (#13939) - steffann
Refactor
- Improve the efficiency of some queries (#13974) - murrant
- Move Config loading to a service provider (#13927) - murrant
Documentation
- Fix typo in dispatcher service doc (#13979) - booth-f
- Fix a typo in alerting doc (#13970) - twelch24
- DOCS, switch to dark or light mode (#13953) - SantiagoSilvaZ
- Assorted cleanups to alerting docs, primarily to make mdl happier (#13950) - VVelox
- Update test doc making it more mdl happy and add a section on writing JSON app tests (#13949) - VVelox
Translation
- Small Italian lang update (#13960) - ppasserini
Misc
Dependencies
- Bump async from 2.6.3 to 2.6.4 (#13947) - dependabot
- Bump composer/composer from 2.2.4 to 2.3.5 (#13944) - dependabot
