22.7.0
(2022-07-20)
A big thank you to the following 21 contributors this last month:
- murrant (12)
- fbouynot (4)
- mwobst (3)
- dependabot (2)
- wrongecho (2)
- ppasserini (2)
- QuadPiece (2)
- Jellyfrog (2)
- enferas (1)
- 00gh (1)
- bennet-esyoil (1)
- VVelox (1)
- rhinoau (1)
- prahal (1)
- paulgear (1)
- duhow (1)
- PipoCanaja (1)
- Mar974 (1)
- ottorei (1)
- mostdaysarebaddays (1)
- dagbdagb (1)
Security
Device
- Missing “s” in NsBsd.php (#14067) - Mar974
- Add full version of Mikrotik logo (#14063) - QuadPiece
- Add apc battery operation time, including display in WebUI (#14058) - mwobst
- Fix the parsing of the temperature unit value (CMCIII devices) (#14056) - mwobst
- Update Mikrotik logo (#14045) - QuadPiece
- Aviat WTM reduce snmp load (#13918) - murrant
Webui
- Fix device filtering false values (#14103) - murrant
- Minor visual changes to the apps-overview page (#14090) - bennet-esyoil
- Search device by MAC via URL (#14072) - duhow
- Add BGP description to eventlog BGP Peers messages (#14061) - mostdaysarebaddays
Alerting
Graphs
Applications
Polling
Authentication
Bug
- Prevent duplicate plugin table entries (#14120) - murrant
- Fix auth_test.php debug (#14118) - murrant
- Fix config seeder will never run (#14113) - murrant
- Reset the opcache after install (#14098) - murrant
- Update config cache on install finalize step (#14097) - murrant
- Fix more webserver validation issues (#14096) - murrant
- Revert “Add apc battery operation time, including display in WebUI” (#14068) - PipoCanaja
- Use --no-patch instead (#14047) - Jellyfrog
Cleanup
Documentation
- Small documentation typos (#14101) - wrongecho
- Documentation typos (#14099) - wrongecho
- Add SELinux configuration for SNMPd on Centos8 in the documentation (#14095) - fbouynot
- Add SELinux configuration for LDAP/AD authentication on Centos8 in the documentation (#14094) - fbouynot
- Add SELinux configuration for Smokeping on Centos8 in the documentation (#14093) - fbouynot
- Add SELinux configuration for RRDCached on Centos8 in the documentation (#14092) - fbouynot
- Corrected API devicegroup curl creation examples (#14081) - rhinoau
- Minor grammar fixes in doc (#14078) - paulgear
- Add documentation for Chrony application monitoring (#14066) - ottorei
Translation
- Few more updates to Ita lang (#14091) - ppasserini
- Italian language update (#14085) - ppasserini
- Adjustments to german translation (#14083) - mwobst
Tests
Misc
Mibs
Dependencies
- Bump terser from 4.8.0 to 4.8.1 (#14123) - dependabot
- Bump guzzlehttp/guzzle from 7.4.4 to 7.4.5 (#14059) - dependabot
