23.1.0
(2023-01-24)
A big thank you to the following 19 contributors this last month:
- electrocret (3)
- peelman (3)
- jasoncheng7115 (2)
- not-known (2)
- da-me (1)
- systeembeheerder (1)
- fdomain (1)
- jaannnis (1)
- knpo (1)
- trs80 (1)
- MANT5149 (1)
- LoveSkylark (1)
- support-capensis (1)
- zeroservices (1)
- dependabot (1)
- dennypage (1)
- carbinefreak (1)
- bnerickson (1)
- Blinq-SanderBlom (1)
- Jellyfrog (23)
- murrant (2)
- SourceDoctor (1)
- PipoCanaja (1)
Device
- Changed discovery OID in ets.yaml (#14795) - da-me
- Added Support for SNS-3615-K9 (#14792) - jaannnis
- Routeros fix lldp discovery on 7.7+ (#14791) - knpo
- Fix cisco-flash (#14772) - electrocret
- Eaton matrix wattage fix (#14770) - peelman
- Add Universal Input Output support for APC (#14766) - dennypage
- Eltek Enexus; Fix SmartpackS divisor and hardware discovery (#14762) - peelman
- Nokia PMC Microwave Improvements (#14761) - carbinefreak
- Add AXOS sensor data for PON Transceivers (the only transceivers Cali… (#14741) - peelman
- Adding discovery of LSI MegaRAID Device Media Errors, Other Errors, a… (#14729) - bnerickson
- Stop net-snmp from interpreting the octet-string from rttMonEchoAdmin… (#14676) - not-known
- Add state of the Fortigate link monitor health checks (#14675) - not-known
- Adding support for loop-telecom devices (#14674) - Blinq-SanderBlom
Oxidized
- Adding Fortigate switches to Oxidized model mapping config (#14782) - LoveSkylark
Bug
- Fix entity-state polling/discovery (#14793) - fdomain
- Update PingCheck.php to remove duplicate “Device status changed to … from icmp check.” event (#14785) - MANT5149
- Fix calculated dbm (#14771) - electrocret
Documentation
- Update Syslog.md (#14794) - systeembeheerder
- Update Authentication.md (#14788) - trs80
- Fix Doc Link for Canopsis transport (#14778) - support-capensis
- Update ElasticSearch Index pattern for php 8.1 changes (#14775) - zeroservices
Translation
- Update zh-TW.json (#14765) - jasoncheng7115
- Create files with Traditional Chinese translation (#14764) - jasoncheng7115
Web UI
- Use displayname instead of hostname for Device Maintenance Modal Title (#14681) - electrocret
Dependencies
- Bump json5 from 1.0.1 to 1.0.2 (#14774) - dependabot
