23.2.0
(2023-02-23)
A big thank you to the following 20 contributors this last month:
- electrocret (5)
- fbouynot (5)
- hanserasmus (3)
- VVelox (3)
- guipoletto (1)
- westerterp (1)
- goebelmeier (1)
- MarlinMr (1)
- florisvdk (1)
- kylegordon (1)
- zenbeam (1)
- dependabot (1)
- gilrim (1)
- murrant (1)
- noaheroufus (1)
- AleksNovak (1)
- tristanbob (1)
- tim427 (1)
- PipoCanaja (1)
- bonzo81 (1)
Feature
Device
- Fortigate IPS Intrusions detected stats (#14857) - electrocret
- Add support for Vsol v1600d EPON OLT (#14853) - guipoletto
- Fix discovery for apc ats (#14837) - florisvdk
- EdgeOS OLT new sensors and changes (#14807) - noaheroufus
- Update XDP string to exclude modern Cisco lightweight APs from discovery (#14803) - tristanbob
- Extend filtering of graphs device_bits on cisco ASA (#14796) - PipoCanaja
Alerting
- Fix MS Teams alert transport, correct HTTP header (#14843) - goebelmeier
- Add support for topics (#14804) - AleksNovak
Graphs
- Update HV::Monitor support to use generic_stats.inc.php (#14814) - VVelox
- Only show Eth errors when Etherlike is enabled (#14784) - electrocret
Applications
Api
- Use Oxidized API client and add support for groups on config get (#14750) - electrocret
Oxidized
- Show display name in Oxidized config search (#14800) - electrocret
Documentation
- Fix Okta image in docs (#14848) - westerterp
- Change socialite settings URI (#14845) - fbouynot
- Fix possible confusion around php-fpm settings (#14844) - hanserasmus
- Use docker compose v2 (#14841) - MarlinMr
- Fix typo in Oauth doc (#14840) - fbouynot
- Add Zenduty Integration info to Transports.md docs (#14826) - zenbeam
- Update config docs - dump current config (#14820) - hanserasmus
- Add SELinux instructions for nginx monitoring (#14812) - fbouynot
- Add SELinux instructions for systemd monitoring (#14809) - fbouynot
- Add SELinux instructions for systemd monitoring (#14806) - fbouynot
- Debian 11 Sury DPA provides PHP 8.2 (#14798) - tim427
Misc
- Use Device displayname on VRF page (#14851) - electrocret
- Include Samsung X Series printers (#14831) - kylegordon
- Fix empty output on validation test (#14822) - hanserasmus
- Revert “Fix entity-state polling/discovery” (#14811) - murrant
- CAPEv2 support (#14801) - VVelox
Dependencies
- Bump symfony/http-kernel from 5.4.16 to 5.4.20 (#14824) - dependabot
