23.4.0 Changelog
23.4.0
(2023-04-06)
A big thank you to the following 25 contributors this last month:
Feature
Device
Webui
Alerting
Graphs
  • Add graph_stat_percentile_disable config item to disable percentile lines/value printing (#14887) - VVelox
  • Convert NTP freq to use generic_stats (#14834) - VVelox
  • Update fail2ban to have better stat graphs and and fix generic_stats graph.php (#14818) - VVelox
  • Update various device graphs to to have better stats (#14815) - VVelox
Applications
Bug
Cleanup
Documentation
  • Fix typo in lnms device:add help (#14937) - arjenz
  • Add Azure example configuration for SAML authentication in documentation (#14870) - fbouynot
Tests
Misc
Dependencies
