23.6.0
(2023-06-23)
A big thank you to the following 14 contributors this last month:
- VVelox (4)
- Jellyfrog (4)
- murrant (2)
- si458 (1)
- netravnen (1)
- tuxgasy (1)
- jepke (1)
- ajsiersema (1)
- wrongecho (1)
- peejaychilds (1)
- tim427 (1)
- kg6uyz (1)
- d-k-7 (1)
- electrocret (1)
- Jellyfrog (9)
- murrant (6)
- electrocret (4)
- ottorei (2)
Feature
Device
- Improve OpenWRT detection (#15096) - tuxgasy
- TEG-S50ES and TPE-P521ES device detection (#15052) - kg6uyz
- Add sensor support for cefcModuleOperStatus (#15026) - d-k-7
- Extend Avocent Support (#14914) - electrocret
Alerting
- Messagebird transport (#15079) - jepke
- Remove asterisk from recurring input (#15074) - wrongecho
- Fix syslog transport output format (#15070) - peejaychilds
- Fixed Markdown/Parse mode for Telegram (#15066) - tim427
Applications
- Add ZFS L2 support (#15095) - VVelox
- Add Linux Softnet Stat app (#15094) - VVelox
- Add Sneck support, making it very trivial to use Nagios style checks in a NRPE like manner (#13954) - VVelox
Bug
- Fixes #14975 Services in Device Groups not displayed correctly in Availability widget (#15076) - ajsiersema
- Fix Dusk tests after 13626 (#15057) - Jellyfrog
