23.7.0
(2023-07-16)
A big thank you to the following 19 contributors this last month:
- peejaychilds (4)
- tuxgasy (3)
- murrant (3)
- jepke (2)
- VVelox (2)
- laf (1)
- PipoCanaja (1)
- eggbeater98 (1)
- illogik (1)
- elianmanzueta (1)
- peelman (1)
- Blinq-SanderBlom (1)
- vincent5753 (1)
- electrocret (1)
- mtentilucci (1)
- edgesite (1)
- davromaniak (1)
- TheMysteriousX (1)
- sjtarik (1)
- murrant (12)
- electrocret (6)
- Jellyfrog (6)
- ottorei (4)
- laf (3)
- PipoCanaja (1)
- FadhliRais (1)
- VVelox (1)
- PJGuyTen (1)
Device
- Fix MPLS Tab Display for Nokia devices using LDP and not RSVP (#15128) - peelman
- Change state value for unplugged linecard (#15126) - Blinq-SanderBlom
- Convert several JunOS sensors to yaml (#15118) - murrant
- Update Trellix NSP discovery (#15117) - mtentilucci
- APC new sensors (#15090) - jepke
- Add regex for Supermicro switches running firmware 2.0 or newer, now called “SuperSwitch” (#15083) - davromaniak
- Add support for PrimeKey Software Appliance (#15059) - TheMysteriousX
Webui
- Update Dark theme for readability on availability map (#15141) - eggbeater98
- Add Oxidized search clarification (#15124) - electrocret
- Sort port by interface name while list ports. (#15093) - edgesite
Alerting
- Alert transport slack config fixes (#15131) - illogik
- Transport Messagebird voice message API (#15115) - jepke
Applications
- Add Privoxy stats support (#15114) - VVelox
- Add Suricata Extract submission stats app (#15105) - VVelox
Api
Discovery
- Fix bogus reply from snmpwalk in ipNetToPhysicalPhysAddress (#15142) - PipoCanaja
Polling
- Fix for hrStorageIndex agility (#15028) - peejaychilds
Bug
- Skip hostnames which are blank when generating the smokeping config (#15144) - laf
- Change chunk to chunkById (#15139) - peejaychilds
- Use lock ports_purge in ports_purge rather than syslog_purge lock (#15135) - peejaychilds
- Fix validation: memcached required only if it is configured in .env (#15122) - tuxgasy
- Exit non-zero if composer bin not found (#15120) - tuxgasy
Documentation
Translation
- Fix typo in delhost.inc.php (#15130) - elianmanzueta
- Added missing zh-tw translation. (#15125) - vincent5753
