24.1.0
(2024-01-07)
A big thank you to the following 37 contributors this last month:
- PipoCanaja (12)
- murrant (7)
- laf (5)
- electrocret (3)
- peejaychilds (3)
- Jellyfrog (2)
- vhuk (2)
- MittWillson (2)
- Bierchermuesli (2)
- netravnen (1)
- iliessens (1)
- sarcastic6 (1)
- SourceDoctor (1)
- altf4arnold (1)
- robje (1)
- rudybroersma (1)
- mtentilucci (1)
- tuxgasy (1)
- craig-nokia (1)
- brianegge (1)
- amyjohn000 (1)
- VirTechSystems (1)
- atj (1)
- lhwolfarth (1)
- bonzo81 (1)
- Sweeny42 (1)
- jduke-halls (1)
- pjordanovic (1)
- dependabot (1)
- TheMysteriousX (1)
- swiftnode-linden (1)
- cguillaumie (1)
- luc-ass (1)
- VVelox (1)
- Leo-FJ (1)
- MaxPecc (1)
- jerji (1)
- Jellyfrog (20)
- murrant (16)
- PipoCanaja (15)
- electrocret (12)
- craig-nokia (1)
- ottorei (1)
Device
- Ignore nameless health sensors for Fortigate (#15678) - iliessens
- Add support for RoomAlert 32S device (#15676) - sarcastic6
- Device - Add Cisco REP Segment state sensor (#15666) - rudybroersma
- Added better support for some HiveOS Wireless devices (#15661) - laf
- Fix HPE iLO CPU Status Sensor Description (#15660) - mtentilucci
- Fix OcNOS detection for recent firmware versions (#15642) - murrant
- Add support for Fortinet FortiAPs (#15641) - atj
- Fixing memory scale for datacom-dmos devices (#15640) - lhwolfarth
- Add support for Forcepoint NGFW 6.10 and older (#15632) - vhuk
- Add memory readings for Draytek OS (#15618) - Sweeny42
- Updated support for HiveOS Wireless newer models (#15610) - laf
- Add HPE iLO 6 to discovery (#15607) - jduke-halls
- Incorrect discovery APC Smart-UPS RT 3000 XL 4.1 ( APC Web/SNMP Management Card (AP9619 MB:v4.1.1 PF:v3.9.4) as multi-phase ups (#15602) - pjordanovic
- Device - McAfee Web Gateway -> SkyHigh Web Gateway (#15596) - PipoCanaja
- Add and extend support for Hirshmann devices (#15588) - cguillaumie
- Updated regex for HWG STE2 r2 to better detect hardware and software version (#15573) - luc-ass
- Update entity-sensor.inc.php for xos’ os (#15552) - Leo-FJ
- Added support of new OS for NTP/PTP systems: Meinberg OS, Safran (Orolia), Oscilloquartz (Adva) (#15453) - MaxPecc
- Zhone health (#15276) - jerji
- Fix wrong ASN discovery on non-BGP Devices (#14948) - Bierchermuesli
Webui
- Clarify In/Out on Ports table. (#15680) - electrocret
- WebUI - Filter FDB and ARP tabs in port page if empty (#15653) - PipoCanaja
- Update Pushover.php (#15652) - brianegge
- Mark old alert email settings as deprecated (#15650) - murrant
- Add bad port settings to webui (#15649) - murrant
- Bug - FDB Table - allow empty searchby as well (#15626) - PipoCanaja
- Update alertlog query to be more efficient (#15622) - laf
- Add vendor to searchby rules function (#15619) - bonzo81
- Fix grabled characters when oid already UTF-8 (#15615) - MittWillson
Graphs
- Change default graph image to SVG (#15586) - electrocret
Api
- API add_device: Add ping_ping fallback option (#15637) - murrant
- More filter options for the BGP peer API endpoint (#15599) - Bierchermuesli
Discovery
Authentication
- Add support for Okta Group claims to set Roles (#15592) - peejaychilds
- Output Roles in auth_test script (#15587) - peejaychilds
Bug
- Fix Rancid error messages (#15683) - vhuk
- Fix smart application parsing (#15672) - SourceDoctor
- Fix pagination in alert rules page (#15659) - tuxgasy
- Bug - “null” checks for SAR 7705 release 8.X (#15657) - craig-nokia
- Bug - missing “use” statement in NTP Cisco (#15656) - PipoCanaja
- Bug - Fix Cisco NTP values (#15639) - PipoCanaja
- Bug - TPLink - fix null exception for LLDP discovery WIP (#15628) - PipoCanaja
- Bug - timos MPLS - more poller fixes (#15624) - PipoCanaja
- Bug - bgp-peers error in Timos -> dbFacile cleanup (#15620) - PipoCanaja
- Bug - ADSL ifIndex to port error not handled (#15617) - PipoCanaja
- Bug - XDSL adslAtucCurrOutputPwr exception (Cisco CSCvj53634) (#15614) - PipoCanaja
- Bug - null checks in Nokia MPLS polling (#15613) - PipoCanaja
- Bug - Nokia discovery protocols (#15606) - PipoCanaja
- Make vminfo.vmwVmGuestOS wider (#15595) - TheMysteriousX
- Fixed state flag causing sql issues in test-template.php (#15589) - laf
Documentation
- Add traceroute to the installed packages doc (#15645) - VirTechSystems
- Fix documentation formatting (#15635) - Jellyfrog
- Fix formatting in OAuth-SAML.md (#15616) - peejaychilds
- Update Debian 12 Installation Instructions. (#15590) - swiftnode-linden
- Add Debian 12 to install docs (#15559) - VVelox
Misc
- Updating the logo to higher resolution one (#15669) - altf4arnold
- Update the type of nummonbssid column in the access_points table (#15647) - amyjohn000
- Fix device format missing display field (#15623) - MittWillson
- Link Model (#15611) - murrant
- Add space to Oxidized error msg (#15603) - electrocret
Internal Features
Mibs
Dependencies
- Update javascript dependencies (#15651) - murrant
- Bump phpseclib/phpseclib from 3.0.21 to 3.0.34 (#15600) - dependabot
