24.11.0
(2024-11-20)
A big thank you to the following 20 contributors this last month:
- eskyuu (15)
- murrant (13)
- laf (6)
- mpikzink (5)
- thundersin (2)
- Calvario (2)
- rudybroersma (1)
- chunned (1)
- netravnen (1)
- PipoCanaja (1)
- opalivan (1)
- dracoling (1)
- dependabot (1)
- peejaychilds (1)
- kkrumm1 (1)
- JeevesTuxis (1)
- jiannelli (1)
- Jellyfrog (1)
- Npeca75 (1)
- kaustubh6199 (1)
- laf (23)
- murrant (19)
- Jellyfrog (10)
- PipoCanaja (3)
- eskyuu (1)
Security
- Fix various display name xss (#16723) - murrant
- Fix custom ports xss (#16722) - murrant
- Fix XSS on ports page (#16721) - murrant
- Additional XSS fixes (#16660) - murrant
Device
- Discovery fix for issue 16544 for ArubaOS-CX (#16739) - rudybroersma
- VRP Transceivers, type + distance details (#16724) - PipoCanaja
- Adva-fsp150cp new OS (#16720) - opalivan
- Add Power sensors (#16708) - mpikzink
- Netvision RFC: Add Socomec Hardware (#16707) - mpikzink
- Convert state sensors from inc.php to yaml (#16704) - mpikzink
- Windows nullable checks (#16702) - murrant
- Convert connection counts to sensors (#16700) - murrant
- Adding sensors for nokia dwdm coherent optical ports (#16699) - thundersin
- Don’t detect PoE Power if no Power is available (#16698) - mpikzink
- Don’t detect stack state if stacking is disabled (#16696) - mpikzink
- Truenas storage fix (#16684) - eskyuu
- Use ifIndex for TPLINK LLDP neighbour lookup first (#16682) - eskyuu
- Fix Stack Topology alert Update procurve.yaml (#16673) - kkrumm1
- Procurve transceiver (#16672) - murrant
- The unbound app creates RRD’s incorrectly, with ‘DERIVE’. (#16671) - JeevesTuxis
- Fortigate - Add SSL VPN Sensor tunnel name (#16656) - Calvario
- Support for TrueNAS-SCALE (new os) (#16655) - jiannelli
- [transceivers] Eltex MES23xx Transceiver support (#16536) - Npeca75
Webui
- Remove breaking qualifyColumn statement (#16716) - dracoling
- Convert device neighbour blade to use components for device and port map pop-ups (#16681) - eskyuu
- Port down list now matches the menu (#16430) - laf
Alerting
- Attempt to fix legacy email alerts (#16730) - murrant
- Add lnms maintenance cleanup command and fix alert rule UI (delete) generating orphans (#16331) - Calvario
Maps
- Fix a bug in the custom map viewer if the device image is invalid (#16694) - eskyuu
- Fix for saveMapSettings() when creating a new map (#16688) - eskyuu
- Bugfix for setting dependency map selected border width (#16685) - eskyuu
- Map performance (#16670) - eskyuu
- Add a new edge option to select the position of the edge text (#16669) - eskyuu
- Add screenshot mode option to custom map widget (#16668) - eskyuu
- Add multi-select support to custom map editor (#16659) - eskyuu
- Update to current version of vis.js (#16657) - eskyuu
- Add new config option for dependency map vis options (#16643) - eskyuu
- Custom Map device images (#16538) - eskyuu
Api
Settings
Discovery
- Changing chromatic dispersion sensor measurement unit to ps/nm (#16697) - thundersin
- VRP Transceivers Support (#16480) - kaustubh6199
Bug
- Fix sensor reset count null (#16727) - murrant
- Fix edge graph pop-up on edge maps (#16693) - eskyuu
- Dont migrate views in 2021_02_09_122930_migrate_to_utf8mb4 (#16687) - peejaychilds
Documentation
Translation
Tests
Misc
- Allow underscores in hostnames (#16683) - laf
- Updated github apply/remove to clear route and view cache (#16470) - laf
