24.12.0 Changelog
24.12.0
(2024-12-17)
A big thank you to the following 32 contributors this last month:
Feature
Security
Device
Webui
  • Correct STP Controller logic (#16885) - PipoCanaja
  • Added support for Sensors/Health in device-summary widgets (#16881) - laf
  • Make the unpolled devices toast point to the unpolled devices page (#16847) - TheMysteriousX
  • Fixed the location filter causing graphs to break (#16804) - laf
  • Resolved issue with interfacepicker using large interface lists (#16790) - InsaneSplash
  • Added ability to re-order alert and device group rules within the builder (#16765) - laf
  • Class device as down even if alerting is disabled (#16758) - laf
  • Refactor indexes on alert_log (#16754) - rkojedzinszky
  • Fix for Navbar overlapping page content when it overflows (#16749) - jaxcentracom
  • New graph design for health sensors (#16731) - mpikzink
  • Stat graph update: adds max and min information for hourly, weekly, and monthly (#16653) - VVelox
  • Adjust decimal places in number_format to be significant figures (#16478) - eskyuu
Alerting
Maps
Snmp Traps
  • Added traphandlers and tests for some Aruba Clearpass traps - take 2 (#16794) - dagbdagb
Applications
  • Fix json-app-tool (#16797) - VVelox
  • Fixed non-numerical hddtemp sensors in unix-agent (#16791) - laf
  • Add graphs to includes/html/pages/apps.inc.php (#16782) - VVelox
  • Add Nextcloud monitoring support (#16769) - VVelox
  • Update the name for Oslv Monitor to display as OS Level Virtualization (#16762) - VVelox
Polling
Oxidized
Bug
Refactor
Cleanup
Documentation
  • Remove the virtual images from the docs (#16793) - laf
  • Add selinux rule to allow cache access from webui (#15688) - fbouynot
  • Fix docs CPU aggregate advanced rule (#15536) - murrant
Misc
Internal Features
Dependencies
