24.2.0
(2024-02-27)
A big thank you to the following 46 contributors this last month:
- rudybroersma (14)
- Npeca75 (10)
- eskyuu (6)
- electrocret (5)
- PipoCanaja (5)
- Jellyfrog (5)
- vhuk (5)
- murrant (5)
- bnerickson (3)
- fbouynot (3)
- FlyveHest (2)
- nickhilliard (2)
- dependabot (2)
- richard-ririe (2)
- laf (2)
- SourceDoctor (2)
- VVelox (2)
- VoipTelCH (1)
- fabriciotm (1)
- dirkx (1)
- swerveshot (1)
- jmesserli (1)
- lrizzi (1)
- Personwho (1)
- OSIRIS-REx (1)
- xorrkaz (1)
- jcostom (1)
- tevkar (1)
- descilla (1)
- arjitc (1)
- My-Random-Thoughts (1)
- dlangille (1)
- blknight88 (1)
- z0d1ac-RU (1)
- lferrerfmv (1)
- gil-obradors (1)
- gunkaaa (1)
- TvL2386 (1)
- santiag0z (1)
- EinGlasVollKakao (1)
- kakohegyi (1)
- i4networks (1)
- Bierchermuesli (1)
- mhamzak008 (1)
- nicklockhart-fullfibre (1)
- LoveSkylark (1)
- PipoCanaja (35)
- Jellyfrog (30)
- electrocret (26)
- laf (21)
- murrant (11)
- mpikzink (1)
- rudybroersma (1)
- ottorei (1)
- vhuk (1)
Feature
- Additional custom map features (#15806) - eskyuu
- API: Add/Remove devices from static devicegroups (#15775) - richard-ririe
- Option to ignore device status (#15697) - SourceDoctor
- Add functionality for custom maps (weathermaps) (#15633) - eskyuu
- Alert Rule Editor: new notes field & SQL field improove (#15631) - Bierchermuesli
- NAC - Improve search in WebUI - Keep Historical data (#15629) - PipoCanaja
Security
Device
- Updated SLA poller for Cisco Nexus 9000 (#15855) - FlyveHest
- Update geist-watchdog.yaml (#15851) - fabriciotm
- Correctly identify FS Datacenter Switch N8560-48BC (#15837) - rudybroersma
- Konica printers additional counters (#15826) - Npeca75
- Add HSRP state sensors for Cisco IOSXE on L3 switches (#15823) - rudybroersma
- Add HSRP Sensor support for IOSXR (#15821) - electrocret
- Add support for Cisco IE1000 (#15820) - rudybroersma
- Initial support for Eltex mes24xx (#15816) - Npeca75
- Add support for Cadant E6000 (#15813) - nickhilliard
- Add LRT-C / LCM-B / LRS-D / LCM-B modules to Luminato model (#15812) - nickhilliard
- Add HSRP state sensors for Cisco IOS on L3 switches (#15809) - rudybroersma
- [rfc1628] Add UPS Test (battery test) status sensor (#15802) - Npeca75
- Add build 22631 as Windows 11 23H2 (#15800) - vhuk
- Zyxel ZynOS PoE Budget sensor support (#15798) - rudybroersma
- Add Procurve NAC support (#15794) - vhuk
- Add ArubaOS-CX VSF state sensor support (#15793) - rudybroersma
- Support for new os/devices, CTS (#15790) - OSIRIS-REx
- Support for new Lancom devices (#15779) - rudybroersma
- Add NAC support for Powerconnect (#15778) - vhuk
- Detect UniFi U7 APs as UniFi AP type (#15776) - jcostom
- FS.com S5810 Discovery fix (#15765) - rudybroersma
- Device - webpower smart II snmp UPS card (#15764) - Npeca75
- Support for temp sensors - WUT Thermometers - W57605 and W57614 (#15757) - rudybroersma
- Initial support for Supermicro BMC (#15750) - Npeca75
- ArubaOS-CX PSU state sensor support & OS and serial detection (#15738) - rudybroersma
- Add FortiSwitch PSU state sensor support (#15735) - rudybroersma
- Added support for Dlink dgs-1250-28x (#15734) - Npeca75
- Add FortiGate DHCP Scope usage percentage sensors (#15727) - rudybroersma
- Added MES 2348B (#15725) - z0d1ac-RU
- Add FortiGate license status sensors (#15722) - rudybroersma
- Handle icmpjitter SLA parsing for iosxe (#15707) - FlyveHest
- Zyxel Wireless Controller OS ( Zyxel NXC series ) (#15694) - kakohegyi
- Device - fix Counter64 octets value in 32bit column bgpPeerInTotalMessages (#15621) - PipoCanaja
- Fix tp-link jetstream FDB discovery (#14321) - Npeca75
Webui
- Disable Page Refresh on Oxidized Tools Page (#15831) - electrocret
- Modify the date selector to use the session timezone (#15783) - eskyuu
- Switch bill_notes input to textarea (#15749) - arjitc
- Sort smart app disks by label (#15686) - SourceDoctor
Alerting
- Add support for Webex max message length. (#15789) - xorrkaz
- Rename JiraServiceManagement.php to Jiraservicemanagement.php (#15717) - gil-obradors
- Add JiraServiceManagement Transport (#15593) - mhamzak008
- Transport - Jira transport rewrite (#15561) - LoveSkylark
Graphs
- Fixed graphs for icmp service showing PL 4 times (#15856) - VoipTelCH
- Socket Statistic Application cleanup and application page graph fixes. (#15845) - bnerickson
Applications
- Deliver output for a specific memcached instance (#15759) - tevkar
- Update nvidia.inc.php (#15756) - descilla
- Add BorgBackup monitoring support (#15591) - VVelox
- Add dhcp-stats tests and update for v3 of the extend (#15378) - VVelox
Billing
Api
- Add API endpoints to update and delete Device Groups (#15774) - richard-ririe
- Add port description API endpoints and documentation (#15578) - nicklockhart-fullfibre
Settings
Discovery
- Fall back to IPV6-MIB IPv6 address discovery if IP-MIB IPv6 address discovery doesn’t return any valid addresses (#15714) - gunkaaa
Oxidized
- Add PollerGroup as an option for OxidizedMap (#15696) - electrocret
Bug
- Update Port Real Time Graph error (#15846) - electrocret
- [bugfix] Fix json-app-tool.php to work with Oid class. (#15844) - bnerickson
- Fix for linkDown/linkUp ifOperStatus (#15835) - PipoCanaja
- Fix “Tempurature” Typo (#15811) - lrizzi
- Bug fixes for the custom maps (#15810) - eskyuu
- Remove dumpRawSql() function in AlertUtil.php (#15803) - Personwho
- Make all image URLs absolute and fix path for viewer (#15788) - eskyuu
- Prevent ansi colors in key:generate output (#15773) - Jellyfrog
- VRP - avoid emptying bgpPeers description at discovery when manually set (#15713) - PipoCanaja
- OSPF instances and missing mandatory fields fix attempt (#15712) - PipoCanaja
- Fixed typo in misc/alert_rules.json with regards to “Space on …” alerts (#15708) - TvL2386
- Don’t escape leaflet tile url in location edit map (#15695) - EinGlasVollKakao
- Show error if “Check Type” field is empty when creating new service template (#15685) - vhuk
Refactor
- Rewrite ups-nut discovery to SnmpQuery:: (#15850) - Npeca75
- Rewrite lmsensors discovery to SnmpQuery:: (#15833) - Npeca75
- Rewrite ipv4 address discovery to Eloquent (#15830) - Npeca75
Documentation
- Applications.md formatting update for better readability. (#15849) - bnerickson
- Update Images.md (#15824) - swerveshot
- More precise OAuth group/role claim information (#15817) - jmesserli
- Add selinux open directory permission for rrdcached in RRDCached.md (#15755) - fbouynot
- Missing dir read permission in sepolicy in RRDCached.md (#15754) - fbouynot
- Update SQL override section after switch to SQL strict mode (#15736) - blknight88
- Add CentOS option to SMART dependency install (#15704) - fbouynot
Misc
Mibs
- Update watchguard MIBs (#15719) - lferrerfmv
Dependencies
- Bump composer/composer from 2.6.6 to 2.7.0 (#15808) - dependabot
- Update PHP dependencies (#15737) - murrant
- Bump follow-redirects from 1.15.3 to 1.15.4 (#15724) - dependabot
