24.3.0
(2024-04-01)
A big thank you to the following 24 contributors this last month:
- rpardim (4)
- dependabot (3)
- electrocret (3)
- bionicman (2)
- PipoCanaja (2)
- eskyuu (2)
- Walkablenormal (2)
- bnerickson (2)
- rudybroersma (2)
- d-k-7 (1)
- murrant (1)
- czarnian (1)
- dmbokhan (1)
- TheMysteriousX (1)
- msaringer (1)
- Didr (1)
- vhuk (1)
- Jellyfrog (1)
- KingDaveRa (1)
- Npeca75 (1)
- dethmetaljeff (1)
- blknight88 (1)
- gunkaaa (1)
- pjordanovic (1)
- Jellyfrog (25)
- electrocret (7)
- PipoCanaja (5)
- murrant (2)
- laf (2)
- mpikzink (1)
- VVelox (1)
Feature
- Support for InfluxDB V2 API (#15861) - Walkablenormal
Breaking Change
- Wireguard application graph cleanup and new wireguard interface/global metrics. (#15847) - bnerickson
Device
- Fix catos discovery (#15915) - d-k-7
- Add health sensors (#15910) - murrant
- Add support for Huawei YunShan OS (#15903) - czarnian
- Add support for Ubiquiti Unifi USP-RPS device (#15900) - bionicman
- Add support for Ubiquiti Unifi LTE devices. (#15899) - bionicman
- Checkpoint Gaia PowerSupply state sensor (#15882) - rpardim
- Add support for Cisco FTD 3105 (#15881) - msaringer
- Fix for Checkpoint Gaia VPN state sensor (#15878) - rpardim
- Support for Forcepoint NGFW 6.11 and later (#15872) - vhuk
- A10 ACOS version, state and count sensors (#15871) - rpardim
- F5 BIG-IP state and count sensors (#15865) - rpardim
- Supermicro bmc updates (#15862) - dethmetaljeff
- YAMLized version of previous PR for Ericsson SSR 80xx routers (#15834) - rudybroersma
- Fix for FortiSwitch RPM/percentage fans (#15829) - rudybroersma
- Move sentry3 current/voltage/power sensors to YAML (#15715) - gunkaaa
- Device - EPSON DS-860 + Network Interface Unit DSBXNW1 (#15420) - pjordanovic
Applications
- Systemd Application Code Cleanup and new Systemd Unit State Metrics. (#15848) - bnerickson
Discovery
- Bug - Fix OSes ‘Junos’ and ‘Hirschmann’ misuse of entPhysicalIndex (#15886) - TheMysteriousX
Bug
- Fix Vrf Table (#15912) - electrocret
- Fix for explicit timezone selection (#15890) - eskyuu
- Bug - fix extra fields in DB entry create/update (#15883) - PipoCanaja
- Remove config_bgp config check in bird2 app (#15877) - Didr
- Custommap label fixes (#15875) - eskyuu
- [ipv4] fix /32 addresses discovery (#15863) - Npeca75
Refactor
- Refactor - remove unused entPhysicalIndex_measured (#15892) - PipoCanaja
Documentation
- Added additional lines for selinux config to work with RHEL8 (#15864) - KingDaveRa
- Fix @signedGraphTag documention (#15853) - blknight88
Tests
- Bump Github Actions to Node.JS 20. (#15873) - Walkablenormal
Dependencies
- Bump express from 4.18.2 to 4.19.2 (#15913) - dependabot
- Bump webpack-dev-middleware from 5.3.3 to 5.3.4 (#15907) - dependabot
- Bump follow-redirects from 1.15.4 to 1.15.6 (#15897) - dependabot
- Update dependencies (#15869) - Jellyfrog
