24.4.0
(2024-04-19)
A big thank you to the following 18 contributors this last month:
- murrant (8)
- PipoCanaja (4)
- xorrkaz (2)
- moisseev (1)
- VVelox (1)
- Taarek (1)
- Melhuig (1)
- dependabot (1)
- Lollbrant (1)
- HolgerHees (1)
- voileux (1)
- hvanderheide (1)
- jasoncheng7115 (1)
- h-barnhart (1)
- Jellyfrog (1)
- CTV-2023 (1)
- fbouynot (1)
- OSIRIS-REx (1)
- Jellyfrog (13)
- murrant (9)
- PipoCanaja (8)
- electrocret (1)
Feature
Security
- Fix Graph date selector (#15956) - murrant
- Fix JS injection in Service Templates (#15954) - murrant
- Fix SQL injection issues in packages search (#15950) - murrant
- Improve order validation in list_devices (#15885) - Jellyfrog
Device
- ILO storage: fix malformed snmp data parsing (#15931) - HolgerHees
- Add Fortigate HA state sensor definition (#15924) - hvanderheide
- Devices - Ciena RLS 6500 (#15909) - h-barnhart
- Cumulus mellanox discovery (#15732) - fbouynot
- Added support for new device OS Westermo WeOS (#15674) - OSIRIS-REx
Webui
Alerting
Graphs
Applications
- For gzip+base64 compressed json, don’t call stripslashes (#15953) - VVelox
- Fix PDNS recursor error (#15942) - murrant
Api
- Add type property to Device class to update it by API (#15930) - voileux
- Add support for a maintenance boolean in API results. (#15904) - xorrkaz
Bug
- Skip rrd sources that do not exist (#15959) - murrant
- Bug - Cisco NAC key error (#15934) - PipoCanaja
- Bug - typo for request rate + sanity on numerical not_null values (#15919) - PipoCanaja
- Bug - vrp - fix signed-tinyint overloaded with disabled radios (#15917) - PipoCanaja
Documentation
- Add missing p5-File-Slurp dependency (#15955) - moisseev
- Fix “lnms config:set” command syntax (#15949) - Melhuig
- Graylog how to set up non-admin user (#15938) - Lollbrant
- Documentation - opcache issue on Debian 12 (#15870) - CTV-2023
Translation
- Fix wrong terminology (#15920) - jasoncheng7115
Dependencies
- Bump tecnickcom/tcpdf from 6.6.5 to 6.7.4 (#15948) - dependabot
