24.5.0
(2024-05-19)
A big thank you to the following 23 contributors this last month:
- murrant (24)
- santiag0z (5)
- eskyuu (3)
- sogadm (2)
- Jarod2801 (2)
- Pikamander2 (1)
- scamp (1)
- ottorei (1)
- whitej46 (1)
- sonic45132 (1)
- fbouynot (1)
- EinGlasVollKakao (1)
- h-barnhart (1)
- sarabveer (1)
- netravnen (1)
- jthiltges (1)
- hatboxen (1)
- electrocret (1)
- washcroft (1)
- Npeca75 (1)
- paulierco (1)
- drshawnkwang (1)
- systeembeheerder (1)
- murrant (22)
- Jellyfrog (13)
- electrocret (3)
- ottorei (1)
- PipoCanaja (1)
Feature
- Custom Maps: geo map and color backgrounds (#16020) - murrant
- Show custom maps in device overview (#15985) - murrant
- New Map Menu (#15969) - murrant
- Mysql PDO options to support SSL/TLS client communication (#15832) - drshawnkwang
- Snmpscan.py output errors and nodns (#15673) - murrant
Breaking Change
Device
- Use null coalescing on Panos.php (#16019) - ottorei
- Improved powerwalker sensors (#15999) - EinGlasVollKakao
- Added initial support for ULAF+ devices (#15997) - Jarod2801
- Correct swapped SET and WHERE parameters in bgp-peers/dell-os10.inc.php (#15983) - jthiltges
- Added FibroLAN devices (#15967) - Jarod2801
- New velocloud devices (#15958) - paulierco
Webui
- Fix issue loading session preferences (#16041) - murrant
- Device location map zoom out when location N/A (#16034) - murrant
- Added read permission test to the custom map model (#16030) - eskyuu
- Do not allow the legend nodes to trigger the node edit modal (#16026) - eskyuu
- Mobile menu full height (#16011) - murrant
- Map Management: Show Groups (#16005) - murrant
- Change custom map editor icon (#16004) - murrant
- Custom Map: Show crosshairs when adding (#15978) - murrant
- On-demand map menu items (#15971) - murrant
- Custom Maps: make edit title clickable (#15965) - murrant
- [webui] sort ports in VLANs blade (#15960) - Npeca75
Graphs
- Fix icmp ping y-axis over 1000ms (#16039) - murrant
- Fix graph_type variable (svg / png) (#15972) - washcroft
Snmp Traps
- SNMP Traps - Ciena AAA (#15998) - h-barnhart
Bug
- Fix downtime in corner cases (#16040) - murrant
- Fix WirelessSensor incorrect model (#16016) - whitej46
- Merge duplicate toBytes functions (#15994) - murrant
- Fix systemd graphs using wrong rrd filename variable (#15988) - sarabveer
- Rrd source does not work with rrdcached (#15974) - murrant
- Git ignore custom map images (#15966) - murrant
- Packet_loss macros quick fix (#15961) - murrant
Cleanup
- Fix incorrect number of seconds in a day (#16042) - Pikamander2
Documentation
- [DOC] Update Customizing-the-Web-UI.md (#16025) - santiag0z
- [DOC] Install LibreNMS: add Icons (#16017) - santiag0z
- Set httpd_cache_t type to /opt/librenms/cache (#16000) - fbouynot
- Update to Material for MkDocs 8.3.9 -> 9.5.20 (#15996) - santiag0z
- Update link to LibreNMS origin blog post (#15981) - hatboxen
- Remove poller_name from docs (#15979) - electrocret
- Update packet_loss docs (#15962) - murrant
- Update Dispatcher-Service.md (#15705) - systeembeheerder
Translation
- Massive changes to the Chinese interface translation. (#16009) - sogadm
- Chinese translation fixesChinese translation fixes (#15991) - sogadm
