24.7.0
(2024-07-17)
A big thank you to the following 25 contributors this last month:
- murrant (28)
- freddy36 (6)
- VVelox (5)
- rudybroersma (2)
- nicolasberens (2)
- electrocret (2)
- slashdoom (2)
- dependabot (2)
- fabriciotm (1)
- TridTech (1)
- PipoCanaja (1)
- Walkablenormal (1)
- jediblair (1)
- westerterp (1)
- Npeca75 (1)
- kanokc (1)
- dennypage (1)
- normand-hue (1)
- peejaychilds (1)
- bonzo81 (1)
- schnobbc (1)
- dasdromedar (1)
- VoipTelCH (1)
- f7naz (1)
- jepke (1)
- murrant (26)
- PipoCanaja (10)
- Jellyfrog (5)
- electrocret (3)
- ottorei (2)
- SourceDoctor (1)
Feature
- Lnms snmp:translate always show textual and numeric translations (#16187) - murrant
- InfluxDBv2 allow filter by group and disable debug by default (#16186) - Walkablenormal
Device
- Fix FortiGate Cluster Sync status (#16206) - rudybroersma
- Add transceiver threshold support (#16203) - freddy36
- Add NAC to Arubaos-CX (#16194) - TridTech
- Add Hardware and frmware detection for moxa P510 (#16185) - nicolasberens
- Fix up the Siteboss571 discovery yaml to split pdnOutputCurrentValue and pdnMainCurrentValue indexes (#16181) - jediblair
- Adjust Line Nominal default limits (#16180) - freddy36
- Add more Synology disk health info (#16178) - westerterp
- Add support for Fiberstore branded Centec switches (#16175) - freddy36
- Fix php issue in cisco ntp code (#16172) - murrant
- Allow for AXIS Panoramic cameras such as the P4707 (#16166) - dennypage
- Add support for Fiberstore branded BDCOM switches (#16162) - freddy36
- Add transceiver monitoring (#16160) - freddy36
- Add support for more Cisco FTD devices (#16150) - normand-hue
- ArubaOS - Addtional support to poll Active VPN sessions (#16137) - schnobbc
- Update eaton-sc200.yaml (#16133) - dasdromedar
- Update axis detection (#16130) - nicolasberens
- New OS broadworks / broadsoft (#16078) - jepke
Webui
- Maps - Keep edge black when link is 0 bps (#16192) - PipoCanaja
- [webui] Ports: correct sorting order when using ifName (#16170) - Npeca75
- Handle missing device when linking (#16164) - murrant
- WebUI - Dark mode menu fix (#16152) - slashdoom
- Fix port link device missing (#16151) - murrant
- Port link component easier graphs (#16147) - murrant
- Fix graph row lazy loading (#16145) - murrant
- Left align text for dashboard widgets (#16138) - bonzo81
- Device Ports settings (#16132) - murrant
- Change port pagination default to 32 (#16131) - murrant
- Ports UI update (#16115) - murrant
Alerting
- Alertmanager, Striptag Dynamic Variables! (#16141) - electrocret
Snmp Traps
Applications
- Add missing graphs for NFS app page (#16197) - VVelox
- Extend update for wireguard, correct is_int to is_numeric for polling purposes, and clean up the app page (#16182) - VVelox
- PHP-FPM app update to handle multiple pools (#16122) - VVelox
- Add some alert template items for CAPEv2 (#16077) - VVelox
- Add generic and improved NFS support with initial support for both FreeBSD and Linux (#15906) - VVelox
Api
- Convert list_arp API to Eloquent (#16111) - murrant
- Fixed wrong column and parameter used when deleting a location via API (#16109) - VoipTelCH
Authentication
Bug
- Fix null in sensors discovery (#16201) - murrant
- Fix incorrect get_class call (#16179) - murrant
- Fix some testing issues (#16174) - murrant
- BGP integer fields fix (#16173) - murrant
- Fix for lnms snmp:translate (#16159) - murrant
Documentation
- Changelog cleanup (#16154) - murrant
- Fortigate append-index doc (#16153) - electrocret
- Clarify okta claim configuration requirement (#16142) - peejaychilds
- [DOC] - Update doc/API/DeviceGroups.md (#16140) - slashdoom
Translation
- Support to Brazilian Portuguese (#16209) - fabriciotm
Tests
- Add entity physical test data (#16183) - murrant
- Add support for snmpsim-lextudio (#16161) - freddy36
Misc
Internal Features
Mibs
Dependencies
- Bump tecnickcom/tcpdf from 6.7.4 to 6.7.5 (#16148) - dependabot
- Bump ws from 8.17.0 to 8.17.1 (#16143) - dependabot
