25.11.0 Changelog
A big thank you to the following 34 contributors this last month:
Feature
  • Validate passwords against compromised password lists (#18380) - murrant
  • Add support for Redis Sentinel sessions. (#17203) - dot-mike
Breaking Change
Security
Device
Webui
Alerting
Graphs
  • Remove the init as part of the Rrd Store construct function (#18501) - eskyuu
Snmp Traps
Api
  • Fix behavior field on maintenance api endpoints (#18368) - tsm1th
Discovery
  • Handle string indexes better, change default flags (#14669) - murrant
Polling
Authentication
Bug
Refactor
Cleanup
Documentation
Translation
  • Add missing EN labels/descriptions for AD Auth Section (#18370) - slashdoom
Tests
Misc
Internal Features
Dependencies
