25.12.0 Changelog
A big thank you to the following 22 contributors this last month:
Feature
  • Add MTU test for devices (#18580) - eskyuu
  • Port parsing better asymmetric speed handling (#18558) - murrant
  • Support bare Git repository of RANCID (#18541) - twogee
  • Add device_stats table to store device related data for alerting (#17041) - eskyuu
Breaking Change
  • Convert rrd_options to an array for use when generating graphs (#18485) - eskyuu
Security
  • Strip html tags from alert rule name and notes for alert rule api (#18646) - laf
Device
Webui
Alerting
Graphs
Applications
Discovery
Polling
Bug
  • Fix adding services via device → edit → service page (#18644) - laf
  • Fixed TPDin and PowerLogic device over graphs (#18637) - laf
  • Fix Dns::getAddresses() (#18610) - murrant
  • Fix location count sorting and improve queries (#18588) - murrant
  • Fix applications sending U value to Datastores (#18573) - laf
  • Avoid DivisionByZeroError (#18571) - heapdavid
  • Update the device_stats migration to make the timestamp field nullable (#18568) - eskyuu
  • Fix config reset to default (#18564) - murrant
  • Fixed wireless sensor count display on device list (#18545) - laf
  • Only add vlan in ports_vlans if vlan exists for VRP devices (#18534) - PipoCanaja
  • Update Ilert transport to fix critical severity (#18525) - tobiasschon
Refactor
Cleanup
Documentation
Misc
  • Update HV Monitor Debian dependencies requirements (#18642) - arjenz
  • If alerting is disabled, show that on polling (#18628) - laf
  • Configure PHP and Python redis clients to use TLS when REDIS_SCHEME=tls (#18617) - mattb0m
  • Create an eventlog on maintenance failure (#18611) - murrant
  • Move notification fetching from daily to a scheduled job (#18247) - Jellyfrog
Internal Features
Dependencies
