25.2.0 Changelog
A big thank you to the following 35 contributors this last month:
Thanks to maintainers and others who helped with pull requests this month:
Feature
Breaking Change
  • Storage Module update (#17024) - murrant
  • Moved currentInUse from custom table to sensors for Cisco ASA (#16952) - laf
  • Convert “Recommended Replace Date” from count to runtime sensor (#16892) - mpikzink
Security
Device
Webui
Alerting
  • Failed with 415 with content type not supported issue (#17110) - jasoncheng7115
  • Updated Grafana transport and docs to support richer information (#16978) - laf
  • Added ZenDuty Transport (#16972) - laf
  • Fix Alert diff, Add new AlertStatus changed, Fix AlertLog UI not showing the correct details (#16313) - Calvario
Graphs
Maps
Discovery
Polling
  • Better handle issues with ipmitool/freeipmi so we try other types as … (#17066) - visbits
Bug
  • Fix wlanAPChInterferenceIndex formula. Fixes Numeric value out of range: 1264 Out of range value for column ‘interference’ (#17171) - w1ll14m
  • Fix storage_perc_warn not being applied to new storages (#17104) - murrant
  • Fix port churn port assoc mode if is non-existent field (#17103) - murrant
  • Fix poller submodule support (#17102) - murrant
  • Fix OS override in device settings (#17095) - murrant
  • Re-add ifIndex index to ports table (#17077) - murrant
  • Replace use of $config with Config::get() in poll-billing (#17072) - laf
  • Fix error in arp-table module (#17031) - murrant
Refactor
  • Remove ObjectCache notifications page (#17100) - murrant
  • Convert Wireless to a modern module (#17086) - murrant
  • Remove snmp_getnext_multi() (#17048) - murrant
  • Get_device_id_by_port_id(x) => PortCache::get() (#16969) - mpikzink
  • Zeropad() => Str::padLeft() (#16960) - mpikzink
  • Improve logging for use of values from SNMP; improve logging for determining multiplier/divisor from YAML (#16949) - gunkaaa
  • Showconfig.inc.php changed svn_log() and svn_diff() to Process() (#16483) - mggaskill
Cleanup
Documentation
Translation
Tests
Misc
Internal Features
Mibs
Dependencies
