26.1.0
(2026-01-12)
A big thank you to the following 28 contributors this last month:
- murrant (22)
- peelman (10)
- laf (9)
- sandap1 (9)
- eskyuu (6)
- peejaychilds (4)
- alagoutte (2)
- jezekus (2)
- dependabot (2)
- freddy36 (2)
- jediblair (2)
- SourceDoctor (1)
- Jellyfrog (1)
- kakohegyi (1)
- erdems (1)
- westerterp (1)
- shrank (1)
- lennarttd (1)
- andrewimeson (1)
- garlic17 (1)
- jakejakejakejakejakejake (1)
- knpo (1)
- VVelox (1)
- xorrkaz (1)
- Serazio (1)
- martinberg (1)
- Fehler12 (1)
- Npeca75 (1)
- laf (48)
- murrant (13)
- copilot-pull-request-reviewer (10)
- Jellyfrog (9)
- PipoCanaja (9)
- peelman (1)
Breaking Change
- Change Algcom SM type to environment (#18730) - murrant
- Allow alerts to match users through device groups (#18720) - eskyuu
- Cisco IE3200 and IE3300 devices are actually IOS-XE (#18654) - knpo
Device
- Adding sensors for Nokia ESA, ISA, and NAT resources (#18770) - peelman
- Add grid power sensor, overload protection (#18763) - peelman
- Update ns-bsd MIBs and detection (#18762) - alagoutte
- Update geist-watchdog detection (#18757) - sandap1
- Corrected sensor name in Ironware OS (#18754) - laf
- Initial support for Alta Labs (#18753) - Jellyfrog
- Fix OID path for connection tracking RouterOS (#18752) - jezekus
- Fix RFC1628 sensors not skipping non-numeric values (#18746) - murrant
- Add Support for Vertiv DCS devices. (#18744) - sandap1
- Add additional sensors for Ironware devices (#18743) - laf
- Add Nokia 1830 PSS device discovery and inventory support (#18739) - peelman
- Add System Resource Usage counts for TiMOS (#18736) - peelman
- Fix fortigate cellular sensors (#18733) - murrant
- Fix Alpha CXC UPS input voltage divisor (#18729) - murrant
- New sensors for FTD (#18721) - kakohegyi
- Update SwOS and add support for SwOSLite (#18718) - jezekus
- Add support for HW-Group Perseus (#18712) - sandap1
- Add support for Zenitel Devices (#18711) - sandap1
- Update Nokia TIMETRA MIBs to latest versions (#18701) - peelman
- Add TransceiverDiscovery interface implementation for Timos OS (#18700) - peelman
- Add Transceiver Support to AXOS (#18699) - peelman
- Add support for Vertiv ITA2 UPS (#18698) - sandap1
- Add apdu10150sm support (#18690) - peejaychilds
- Improve transceiver support for BDCom (#18684) - freddy36
- Add support for SmartByte OS (#18681) - freddy36
- Add support for insyde - Supervyse (OpenBMC) (#18679) - sandap1
- Add SmokeSensors to APC NetBotz 750 (#18675) - peejaychilds
- Add support of IPBS3 for Ascom devices (#18668) - alagoutte
- Add APC Schneider Electric NetBotz 750 (#18665) - peejaychilds
- Fix MTS-COM rectopenstate inverted (#18660) - jakejakejakejakejakejake
- Add support for Cisco FTD 4245. (#18645) - xorrkaz
- Updated Alpha CXC support (sensors and hardware version) (#18643) - laf
- Add support for Pandacom Equipment (#18636) - Serazio
- Updated VyOS detection (#18624) - laf
- Add support for Tailyn Equipment (#18612) - sandap1
- Added POE data for Advantech Switches (#18601) - sandap1
- Add iDRAC RAID rebuild progress and SSD write endurance (#18599) - jediblair
- Incuded 7.4 Audiocodes MIBs and fixed call counter (#18555) - Fehler12
- MIKROTIK-MIB update (#18479) - Npeca75
- Update Tailyn OS logo & os icon from PNG to SVG (#18695) - sandap1
- Add CloudLinux OS logos (#18686) - lennarttd
Webui
- Devices page fix selected os text (#18759) - murrant
- Round Celsius temperature values to 2 decimal places (#18747) - peelman
- Fix ghost X bug in multiport selector widget (#18707) - peelman
- Add multi-sensor graph aggregation for dashboard widgets (#18706) - peelman
- Added age and message filter to eventlog widget (#18687) - shrank
- Allow to hide totals in availability map (#18677) - garlic17
- Service last_changed time display bug fix (#18673) - jediblair
- Update poller blade to be timezone aware (#18656) - eskyuu
- Panel component body class fix (#18647) - murrant
Alerting
Graphs
Billing
Api
Discovery
Authentication
Bug
- Fix scheduler maintenance.log path (#18775) - murrant
- Fix maintenance:fetch-rss relative path (#18766) - murrant
- Fix for generic_multi.inc.php (#18740) - eskyuu
- Fix rector mistake (#18697) - murrant
- Fix mtu status changed event log 1 → 1 (#18683) - murrant
- Configure output for all commands (#18669) - murrant
- Fix alerts in app/Jobs/PingCheck.php (#18666) - eskyuu
- Fix packet size calculation for MTU test (#18663) - eskyuu
Cleanup
- Change useless log from warning to debug (#18765) - murrant
- Drop non-functioning (and redundant) parameter $sloped_mode (#18694) - westerterp
- Parse email cleanup (#18619) - murrant
Documentation
- Clarify in the docs to use MIB-NAME::OID (#18756) - laf
- Update Docs for NTP-Server Application rewrite (#18755) - SourceDoctor
- Fix documentation typos, fix Procurve/Aruba command quotes (#18682) - andrewimeson
- Add docs about additional_oids (#18625) - martinberg
Misc
- Fix discover log target (#18774) - murrant
- Maintenance:cleanup-syslog run hourly (#18737) - murrant
- Update maintenance:rrd-step to work with rrdcached (#18623) - murrant
Dependencies
- Bump paragonie/sodium_compat from 1.23.0 to 1.24.0 (#18750) - dependabot
- Bump composer/composer from 2.9.1 to 2.9.3 (#18726) - dependabot
