After last night’s upgrade to 26.10.0 via the daily script, all of my ack’d alerts and notes are gone, all of the alerts re-triggered as new. I doubt there is an easy way to get this back, but I figured I would post as a bug report. I’m going to dump the new alert table and compare it to the old and see if I can restore it.
[OK] Composer Version: 2.10.3
[OK] Redis is functional
[OK] No errors found with polling frequencies.
Thanks for reaching out. This is understandable, lots of moving parts here, I was able to get things moved over and the existing alerts ACK’d.
One thing I just discovered was the per-entity alerts. I tried to use it today and it now shows individual alerts per-interface on my devices, a nice feature! However, what I found was that when a new interface goes into alert, the existing interface alerts (that were ACK’d on the same device) also go un-ack’d. In my case I had 3 ack’d alerts for a device, when a new interface went down, I now had 4 un-ack’d active alerts. An email was only sent out for the one, but Im sure I would get re-alerts for the other 3 when the time came.
