26.3.0 Changelog
big thank you to the following 37 contributors this last month:
Breaking Change
Device
Webui
  • Stop use of xss in device show config (#19218) - laf
  • Updated graph background when dark mode used (#19201) - laf
  • Modernise device edit health page (#19162) - laf
  • Fix 2FA QR code scanning in dark mode (#19141) - murrant
  • Fix SQL query when looking at all outages (#19116) - eskyuu
  • Updated links to ports from Device overview page (#19067) - laf
  • Fix alert log widget rule name (#19062) - murrant
  • Improve the usability of the dashboard drag/drop widgets (#19055) - laf
  • Add search to device ports tab (#18997) - Jannos-443
  • Set timezone display based on user preference (#18977) - murrant
  • Device-overview add clickable email & underline coordinates (#18605) - bennetgallein
Alerting
Snmp Traps
  • SNMP Trap: Add SNMP trap handler for PowerNet-MIB communicationEstablished and ApcLowBattery (#19225) - chris9951
  • Use ‘trap’ log type in Zebra printer handlers (#19194) - chris9951
  • SNMP Trap Handler: Extend German SNMP trap translations for Zebra printers (#19185) - chris9951
  • SNMP Trap Handler: Apc ups test and discharge traps (#19183) - chris9951
  • Add additional German translations for Zebra SNMP trap handler (#19171) - chris9951
  • Adds SNMP trap handlers for Zebra Link-OS label printers (#19061) - chris9951
Applications
Api
Discovery
Bug
Refactor
Cleanup
Documentation
  • Add note/work around to GPSD extend being slow thanks to gpspipe and explain mode int (#19134) - VVelox
  • Fixed mariadb configuration doc for Debian 13 (#19105) - lrizzi
  • Add example for extending alert templates (#19064) - Serazio
  • Updated docs to reflect use of MIB::OID usage in yaml and code (#19051) - laf
  • Clarifies API routes and updates documentation (#19044) - mhajder
Misc
Internal Features
Dependencies
