26.4.0 Changelog
26.4.0
(2026-04-19)
A big thank you to the following 36 contributors this last month:
Feature
Breaking Change
Security
Device
Webui
  • Improve visual space for device actions (#19469) - murrant
  • Added severity buttons to Alert widget filter (#19466) - laf
  • Updated Widgets controller to check for user access (#19465) - laf
  • Fix unhandled Oxidized ConnectionException causing CRITICAL crash on device config tab (#19443) - eduardomozart
  • Use localized timezone for Last Polled and Last Discovered in Device Edit view (#19426) - eduardomozart
  • Add 90-day availability bar to device overview (#19342) - Palerm0
  • FDB tables don’t show duplicate IPs (#19303) - murrant
  • Permissions refinement (#19295) - murrant
  • Remove duplicate font-size in geomap, improve accessibility (#19285) - as8net
  • Added filter for sensors to filter for errors, warning, alert and unknown values (#18639) - shrank
  • Add option for ports controller to use ARP/MAC table lookup for IPv4 neighbours (#16899) - eskyuu
Alerting
Applications
  • Update to support form factor, rpm, and over temp info from extend, update docs, minor poller fixes, and add more alert examples (#19169) - VVelox
Api
  • Added ability to specify graph type to override system settings in api (#19343) - laf
  • Device groups API: Allow device groups to contain an empty list of devices (#19299) - richard-ririe
Discovery
  • Modify cron example to use lnms device:discover new (#19344) - murrant
Authentication
  • Socialite decouples token attribute lookup from OAuth scopes (#19296) - Jannos-443
Bug
Refactor
Cleanup
Documentation
Tests
Misc
Internal Features
  • Capture more complete debug logs when running tests (#19316) - eskyuu
Dependencies
