26.5.0 Changelog
26.5.0
(2026-05-18)
A big thank you to the following 27 contributors this last month:
Feature
Breaking Change
  • Remove default fortigate → fortios match for Oxidized config (#19598) - casdr
  • Cleanup dbSyncRelationship and dbDelete and remove manage_bills.php script (#19583) - mpikzink
  • Change default APP_TRUSTED_PROXIES to 127.0.0.1 (#19537) - murrant
Security
Device
Webui
Graphs
  • Prevent graph title from being cropped off on both sides (#19589) - murrant
Snmp Traps
Api
Settings
  • Interface parsing docs+settings improvements (#19633) - murrant
Discovery
  • Updated tpdin sensors skipping 0 values (#19507) - laf
  • Add FDB table support for Nokia TiMOS devices (#18713) - peelman
Bug
  • Fixed MapQuest API url (#19671) - szastan
  • Remove dead scopeLimit on Notification model (breaks daily.sh under Laravel 11) (#19669) - swaymel
  • Fix double-encoded builder/extra in alert rule legacy API (#19666) - Starson323
  • Fix graph time picker redirect 404 (#19648) - HaradaKumiko
  • Fixes Xdsl.php when the SNMP response data in an unexpected format (#19641) - sherlvoodi-create
  • Fix link to port on Inventory page (#19597) - laf
  • Added more defaults to OSPFv3 area fields missing from Arista (#19588) - laf
  • Fix logic for dev commands (#19586) - mpikzink
  • Fix SSL Certificate menu hiding on lower sized screen res (#19571) - laf
  • Mistyped variable name breaking custom OID (#19569) - JHarmonPMU
  • Handle GBK-encoded interface names and descriptions in ports polling (#19528) - Yish1
  • Zynos/Zyxel fix port ifName between 50 and 63 (#19341) - Yanonix
Refactor
Cleanup
Translation
Misc
  • Fix uninitialized variables in smokeping graph templates (#19599) - bdg-robert
  • Add check_dnssec_delegation override (#19591) - 49phil
  • Fall back to IEEE 802.3ad LAG-MIB when ifStackTable is missing (#19574) - shward
  • Fix BGP peer device links incorrect with reused IP address space (#19394) - Starson323
Dependencies
