26.6.0
(2026-06-15)
A big thank you to the following 32 contributors this last month:
- murrant (43)
- laf (28)
- dependabot (8)
- maggo1404 (3)
- tristanbob (3)
- Yoyasp (2)
- knpo (2)
- sergio-scl (2)
- craig-nokia (2)
- peelman (2)
- 49phil (2)
- takyanagida (1)
- Taarek (1)
- loopodoopo (1)
- danpal-dev (1)
- lirone (1)
- thundersin (1)
- WizballESY (1)
- robje (1)
- InsaneSplash (1)
- eskyuu (1)
- danjul89 (1)
- Npeca75 (1)
- moyito2604 (1)
- eduardomozart (1)
- isolson (1)
- anthonyp-cns (1)
- mpikzink (1)
- redundantredundancy (1)
- Jannos-443 (1)
- CCAkoutsio (1)
- LongHopeFreedom (1)
- laf (67)
- murrant (32)
- copilot-pull-request-reviewer (3)
- Jellyfrog (1)
Feature
Security
- Update storage table to remove xss (#19896) - laf
- Added validation for ajax/select/port filter (#19877) - laf
- Check user has permission to access port for search_by_mac api function (#19876) - laf
- Stop leaking data when host add fails via api (#19870) - laf
- Stop widgets being moved that don’t belong to that dashboard (#19868) - laf
- Fix some possible xss in various tables (#19867) - laf
- Validate wireless sensor updates against static list (#19863) - laf
- Add device permission check to add_eventlog api call (#19862) - laf
- Added a csrf check into ajax_form.php (#19859) - laf
- First round of updates to improve security (#19856) - laf
- Permissions implementations and improvements (#19643) - murrant
Device
- IOS-XR ignore optical and macsec if types (#19889) - knpo
- Add Versa Networks SD-WAN support (#19849) - loopodoopo
- Adding FMMC ports to iqnos dBm sensors (#19806) - thundersin
- Deltaups voltage divisor for Mini-SNMP firmware (#19797) - sergio-scl
- Add Albentia WiMAX BS support (#19796) - sergio-scl
- Add Moxa NP6150 sysObjectID (#19786) - WizballESY
- Updated OcNos transceiver to port mapping (#19783) - laf
- Add basic Nokia Wavence microwave support (#19750) - craig-nokia
- Add initial support for Genie ATM (#19739) - robje
- Set max oid 5 for exeltech-xfersw (#19722) - murrant
- Version-dependent divisor for SmartpackS rectifiersCurrent (#19718) - peelman
- Add ENVIROMUX 2D/5D/16D support and enrich E-MICRO-TRH(P) variant (#19717) - peelman
- Support RutOS 7.x table-based MIB (#19689) - danjul89
- Add GE Pulsar power system alarm sensors (#19681) - craig-nokia
- Liebert IntelliSlot Web/485 support (#19654) - moyito2604
- Add RoomAlert MAX support (#19435) - redundantredundancy
- Fix Conteg PDU divisor for power sensors (#19384) - CCAkoutsio
Webui
- Ports page better indicator colors (#19884) - murrant
- Fix Metro Ethernet table (#19854) - laf
- Fix graph time presets for week and month units (1w/2w/1mo/2mo) (#19835) - tristanbob
- Fix the device Access Points page using light coloured background (#19809) - laf
- Device overview graphs fill better (#19807) - murrant
- Update label for default group when using Socialite (#19791) - laf
- Fix alert detail sensor graph (#19781) - murrant
- Modals now appear lower than the navbar and reduced the gap below the navbar (#19777) - laf
- Increase device and port popup show delay (#19770) - murrant
- Add index to device display field (#19768) - murrant
- Filter bar widget search button shortcut (#19763) - murrant
- Port state filter refinement (#19762) - murrant
- Devices page handle legacy url filters (#19757) - murrant
- Filter handle empty and not empty better (#19756) - murrant
- Fix alert history graph when empty (#19751) - murrant
- Device Overview page UI updates (#19731) - laf
- Devices filter (#19725) - murrant
- Fix device inventory port link escape (#19723) - murrant
- Re-order port filters (#19719) - murrant
- Fix access permissions on port group list and page (#19714) - eskyuu
- Added port security filter and csv export (#19692) - laf
- Add graylog.match-any-address configuration option (#19445) - anthonyp-cns
Alerting
Api
- Add invert_map to add_edit_rule (#19890) - Yoyasp
- Add statistics to get_port_info (#19824) - knpo
- Add wireless sensors endpoint (#19461) - isolson
Discovery
Polling
Authentication
- Radius include message authenticator (#19715) - InsaneSplash
Bug
- RRD tune error handling (#19873) - murrant
- Fix issue with assigning some config types (#19869) - laf
- Filterable, bail on non-array (#19853) - murrant
- Decode legacy location names (#19852) - murrant
- Change “vsz” column to BigInt (#19851) - Taarek
- Rrd fix getRrdFiles (#19843) - murrant
- Fix rrdcached directory replacement (#19842) - murrant
- Directory cannot be a binary (#19839) - murrant
- Walk volume status table in storage discovery (#19826) - lirone
- Repair Show Previous on multi-interface bits graphs (#19821) - tristanbob
- Remove redundant ob_end_clean() after ob_get_clean() (#19811) - tristanbob
- Unifi avoid crash from bad response (#19766) - murrant
- Fix Janitza device detection (#19765) - murrant
- Update links to device groups and types (#19748) - laf
- Fix device:add display name flag (#19744) - murrant
- Fix duplicate eventlog for device attribute changes in some cases (#19740) - murrant
- Fix for orphaned alerts when device_id =< 0 (#19709) - laf
- Decode non-ASCII printer supplies descriptions (UTF-8 CJK support) (#19379) - LongHopeFreedom
Refactor
Cleanup
- Removed unused alert function and code (#19894) - laf
- Fix update ports error (#19874) - murrant
- Remove duplicate rrdtool version code (#19841) - murrant
- Rrd more robust error handling (#19840) - murrant
- Remove enable_footer config option (#19819) - laf
- Cisco port security code improvements (#19733) - murrant
Documentation
- Clarify interface parsing asymmetric speed (#19875) - murrant
- Minor improvement of Configuration doc (#19864) - takyanagida
- Update Distributed-Poller.md to reference billing module (#19474) - eduardomozart
- Additionally documentation for microsoft socialite roles (#19423) - Jannos-443
Translation
- German translation improvements #1 (#19855) - maggo1404
- Add Spanish (es) translation (#19834) - danpal-dev
- German translation improvements #2 (#19829) - maggo1404
- German translation improvements #3 (#19716) - maggo1404
Tests
Misc
- Add check_zone_auth override (#19632) - 49phil
- Add check_zone_rrsig_expiration override (#19629) - 49phil
- Cleanup set_dev_attrib (#19442) - mpikzink
Dependencies
- Bump esbuild, vite and laravel-vite-plugin (#19893) - dependabot
- Bump guzzlehttp/psr7 from 2.9.0 to 2.11.0 (#19887) - dependabot
- Rrdtool minimum version 1.5.5 (#19837) - murrant
- Bump axios from 1.15.2 to 1.16.0 (#19789) - dependabot
- Bump symfony/yaml from 7.4.10 to 7.4.12 (#19776) - dependabot
- Bump symfony/mailer from 7.4.8 to 7.4.12 (#19775) - dependabot
- Bump symfony/mime from 7.4.9 to 7.4.13 (#19774) - dependabot
- Bump symfony/http-kernel from 7.4.10 to 7.4.13 (#19773) - dependabot
- Bump symfony/routing from 7.4.9 to 7.4.13 (#19771) - dependabot
