26.7.0 Changelog
26.7.0
(2026-07-20)
A big thank you to the following 39 contributors this last month:
Feature
Breaking Change
  • Validate port parsing script lives in includes/ folder and is a php f… (#19865) - laf
Security
  • Security fix for VRF displayName xss (#20096) - laf
  • Security fix for F5 file inclusion (#20093) - laf
  • Security fix for PeeringDB xss (#20091) - laf
  • Security fix for Wireless edit page (#20090) - laf
  • Security fix for procedure URLs in alerts table (#20088) - laf
  • Security fix for Graph group and nfsen includes (#20087) - laf
  • Escape url helpers more consistently (#20004) - murrant
  • Update PHP dependencies (#19932) - murrant
  • Added permissions to editing/viewing notes (#19861) - laf
Device
Webui
Alerting
Graphs
Applications
Billing
Api
  • Fix Services API to allow optional name (#20079) - laf
  • Fix health API returning empty results for processor, storage and mempool (#19953) - abhishekambastha
Polling
  • Poll port-channel membership so changes are visible within one poll cycle (#19620) - shward
  • Only update ping stats in poller and improve fast ping speed (#18674) - eskyuu
Authentication
Bug
  • Increase access_points.interference to a smallint (#20118) - laf
  • Fix bill graph 95th percentile calculation under ONLY_FULL_GROUP_BY (#20102) - Gez7
  • Fix hp blade system fan+psu discovery (#20075) - si458
  • Stop bad entStateLastChanged breaking entity-physical discovery (#20072) - laf
  • Sync modules to OS Schema to fix config:set (#20070) - laf
  • Changing status reason should not trigger a log message (#20035) - murrant
  • Device_display_default setting should invalidate device display name cache (#20032) - murrant
  • Fix unix agent not polling (#20029) - murrant
  • Fix undefined variable $all_return with legacy extend script output (#20027) - MHammett
  • Fix/graphpopup mini graph size (#20003) - Torstein-Eide
  • Fix device existence check (#20002) - murrant
  • Alter REP Segment numbering to match Cisco’s numbering (#19999) - rudybroersma
  • Fix bad ports-stack module function call (#19996) - murrant
  • Fix boolean filters showing Yes for 0 when accessed from url (#19992) - laf
  • Expand eventlog columns and truncate interface column (#19974) - laf
  • Cleanup SslCertificate Model (#19970) - murrant
  • Query Builder cleanup (#19967) - murrant
  • Proxmox ignore bad input (#19965) - murrant
  • Fix the dashboard widgets edit/delete (#19962) - laf
  • Updated mpls_saps.sapsDescription to 160 varchar (#19959) - laf
  • Normalise null details at load site in RunAlerts (#19958) - Starson323
  • Changed master channel exit code to 2 (#19954) - laf
  • Restore edit device functionality (#19934) - laf
  • Fix bill pages using unset variables (#19921) - laf
  • Api device add display template (#19920) - laf
  • Rrdtool, ignore errors from libraries (#19907) - murrant
  • Make sure some variables are defined in the disk_bits/generic_data graphs to fix missing variable errors (#19831) - eskyuu
  • Fix GPS location not stored due to empty location name for Fortigate devices (#19827) - Palerm0
  • Raise satellites/satellites_used RRD max from 40 to 200 for multi-constellation receivers (#19655) - octalparrot
Refactor
Cleanup
Documentation
  • Updated Alert Template documentation to add warning (#20092) - laf
  • Update documentation - rrdcached and rrd cleanup (#19879) - Jannos-443
Translation
Tests
Misc
Internal Features
Dependencies
