26.9.0
(2026-09-20)
A big thank you to the following 45 contributors this last month:
- murrant (51)
- bennetgallein (12)
- eskyuu (6)
- laf (5)
- peejaychilds (4)
- dependabot (4)
- ji03mmy18 (3)
- bennet-agital (2)
- ahoogerhuis (2)
- Jannos-443 (2)
- Jellyfrog (2)
- alexc-hue (1)
- itsbb94 (1)
- hrtrd (1)
- heitbaum (1)
- Wenkow (1)
- SourceDoctor (1)
- hipzilla (1)
- dragosbdi (1)
- signalgridco (1)
- XBLOssia (1)
- sthompson-beanfield (1)
- shoogland-etn (1)
- devilrob (1)
- christoffer15 (1)
- todd799 (1)
- matteo-didone (1)
- statio (1)
- ShaneMcC (1)
- draxien (1)
- gszigethy (1)
- Yavoreo (1)
- jacobw (1)
- OP-Prajwal (1)
- MarlinMr (1)
- Starson323 (1)
- dot-mike (1)
- takyanagida (1)
- rjvannugteren (1)
- 0uwl (1)
- TheGislum (1)
- psreekrishnan (1)
- riborg (1)
- yeager (1)
- VVelox (1)
- laf (48)
- murrant (43)
- bennetgallein (25)
- Jellyfrog (3)
- Atroskelis (1)
- eskyuu (1)
Feature
Security
- Improve network and dependency map defaults, remove settings (#20574) - murrant
- Fix services graph (#20551) - murrant
- Escape default alert title definition (#20547) - murrant
- Sanitize user and group inputs in LDAP search filters (#20542) - murrant
- Enforce lockout and rate limiting during 2fa token verification (#20541) - murrant
- Prevent directory traversal in nfsen channel parameter (#20540) - murrant
- Escape device displayName and sensor_descr to prevent sto… (#20539) - murrant
- Fix oxidized xss (#20538) - murrant
- Convert legacy API tokens to modern tokens (#20528) - murrant
Device
- Add PoE power sensors for Netgear GS324TP (#20567) - itsbb94
- Add SNR-OLT-GPON-16-2AC support (#20558) - hrtrd
- Add support for Palo Alto Networks Prisma SD-WAN ION (formerly CloudGenix) (#20556) - heitbaum
- Add hardware, serial, version and features for Liebert (#20522) - hipzilla
- Fix inventory loop because of duplicate index (#20518) - bennetgallein
- Fix connection tracking sensors and skip empty SFP cages for RouterOS 7.24 (#20517) - dragosbdi
- Added support for SAF Freemile 60 (#20504) - laf
- Add Edgecore ECS4650 support and power status for ECS4150/ECS5520 (#20501) - ji03mmy18
- Fix panduit yaml (#20493) - murrant
- Add Vertiv PDU GTHD temperature and humidity sensors (#20480) - devilrob
- Teltonika rutos-rutm fixed sysObjectID (#20478) - christoffer15
- Detect HPE iLO 7 (Gen12), sysObjectID .1.3.6.1.4.1.232.9.4.13 (#20475) - matteo-didone
- PanOS GP VPN Active Sessions – remove meaningless low limit, wire up real high limit (#20454) - ahoogerhuis
- Add Edgecore ECS4150 and ECS5520 support (#20445) - ji03mmy18
- ZTE ZXA10: use ifName as the port label (#20434) - draxien
- Update high_limit from PAN-OS vsys Active Sessions sensor (#20430) - ahoogerhuis
- Detect newer Ruckus Unleashed APs that relocated their MIB to .25053.1.15 (#20423) - Yavoreo
- Add Planet MC-1610MR / MC-1610MR48 chassis support (#20329) - 0uwl
- Add ASRock Rack BMC support (asrockrack) (#20297) - TheGislum
- Add Support for Cisco ISE SNS-3655-K9 (#20228) - riborg
Webui
- Device filter status down should not filter on disable notify (#20580) - laf
- Migrate debug capture tab to laravel (#20563) - murrant
- Filter bar scroll when too wide (#20553) - murrant
- Authorize port delete permissions on purge action (#20544) - murrant
- Custom maps improvements for zoom and interactions (#20535) - murrant
- Modernize vminfo page (#20516) - bennetgallein
- Custom Map: allow device os image to be set as the default (#20512) - murrant
- Fix custom map background (#20511) - murrant
- Fix display of memory in eventlog when Vms are discovered (#20508) - bennetgallein
- Added display for poller environments (#20505) - laf
- Custom Maps: Add many more Font Awesome icons for use (#20496) - murrant
- World map, custom tile_url and query params (#20490) - bennetgallein
- Switch to popper 2 globally via npm (#20441) - bennetgallein
- Fix port hover graphs on device overview page (#20440) - bennetgallein
- Config backup UI refinements (#20420) - murrant
- Refactor device munin tab to Laravel (#20412) - murrant
- Convert the capture commands to laravel (#20396) - eskyuu
- Add table support to health-sensors and sort by value (#20368) - dot-mike
- World Map widget, auto-scale turn on/off toggle in widget settings (#20334) - rjvannugteren
- Port/portsecurity hostname search - include sysname and displayname in search (#20319) - Jannos-443
- Add gui setting for network map options (#20128) - Jannos-443
Alerting
- Add Signalgrid alert transport (#20513) - signalgridco
Graphs
Applications
Billing
Api
- Save the alert rule procedure URL sent to the API via /api/v0/rules (#20568) - peejaychilds
- API - Location Update fix (#20537) - SourceDoctor
Bug
- Catch malformed dates in Time::dateToMinutes() (#20577) - alexc-hue
- Widen entPhysicalFirmwareRev (#20561) - bennetgallein
- BGP peer context duplicates during discovery (#20560) - bennetgallein
- Fix fputcsv() deprecation warning in table CSV export (#20549) - Wenkow
- Fix graph query parsing (#20546) - murrant
- Fix br escaping on global BGP page (#20533) - bennetgallein
- Fix yaml snmpget exists checks (#20532) - murrant
- Fix up regex on RRA split in RRD storage driver (#20523) - eskyuu
- Macros in config defs (#20510) - murrant
- Fix vminfo 500 table if parent device went missing (#20507) - bennetgallein
- Fix never ending outages (#20506) - bennetgallein
- Fix PortTabHook plugins never appearing on port page (wrong PortTabHook import) (#20498) - XBLOssia
- BGP error code don’t pass nulls (#20492) - murrant
- Fix alert transport error with null config (#20488) - bennetgallein
- Fix date_or_relative validation rejecting mo and s units (#20487) - sthompson-beanfield
- Fix device display name regeneration repeating the first chunk (#20486) - shoogland-etn
- Resolve composer.plugins.json against the install dir, not the cwd (#20472) - statio
- Restore missing SQL statements from debug output (#20471) - eskyuu
- Fix discovery swallowing the first jnxContents row (#20453) - peejaychilds
- Delete device orphans without locking the devices table (#20452) - peejaychilds
- Remove $this->authorize(view, $device); check to allow port-only users to view ports. (#20447) - ShaneMcC
- Config backup: on load error hide the old config (#20443) - murrant
- Fix device note and other permissions check (#20421) - bennet-agital
- Prevent db disconnect from breaking syslog processing (#20400) - jacobw
- Fix bgpLocalAs showing up as negative for 4-byte ASNs (#20399) - OP-Prajwal
- Always close open outages when device recovers, even during maintenance (#20380) - Starson323
- Use sla_nr as part of SLA discovery composite (#20295) - psreekrishnan
Refactor
- Migrate Bill Actions to Laravel (#20545) - murrant
- Snmp.inc.php use NetSnmp (#20489) - murrant
- Refactor SNMP target out of config (#20483) - murrant
- Notifications form laravel (#20463) - murrant
- Snmp backend interface (#20460) - murrant
- Syslog parser - reduce memory usage (#20448) - murrant
- Device routing tab refactor (#20428) - murrant
- Refactor device MEF tab to Laravel (#20411) - murrant
- Refactor device packages tab to Laravel (#20410) - murrant
- Refactor device inventory tab to Laravel (#20409) - murrant
- Device tab refactor printer (#20408) - murrant
- Refactor device services tab to Laravel (#20407) - murrant
- Refactor device alert stats tab to Laravel (#20406) - murrant
- Refactor device tnmsne tab to Laravel (#20405) - murrant
- Device tab refactor processes (#20404) - murrant
- Refactor device pseudowires tab to Laravel (#20403) - murrant
Cleanup
- SnmpQuery interface bulk toggle (#20502) - murrant
- Removed rrdcheck from validation (#20485) - laf
- Convert measurement manager to use the Console_Color2 colour library to set colours in output (#20444) - eskyuu
- Improve Device::findByIp (#20401) - murrant
- Add filter on the device prefetch in the device group update action to reduce unneeded SQL traffic (#20336) - eskyuu
- Dispatcher polling frequency - fallback to rrd.step (#19059) - eskyuu
- Distributed poller: optionally pause intake under memory pressure (#17482) - peejaychilds
Documentation
- Updated OS developer docs and skill (#20499) - murrant
- Fix config key name and clean up malformed example JSON in VisJS docs (#20476) - todd799
- Adjust side navigation below OS support docs (#20346) - takyanagida
Translation
Tests
- Replace SnmpQueryMock with SnmprecSnmpBackend (#20529) - murrant
- Fix CI tests snmpsim wait heuristic (#20425) - murrant
Misc
Internal Features
- Extract hasIp scope from findByIp (#20424) - murrant
- Only deploy docs when running on upstream repository (#20394) - MarlinMr
Mibs
Dependencies
- Bump nanoid from 3.3.16 to 3.3.19 (#20564) - dependabot
- Bump composer/composer from 2.10.2 to 2.10.3 (#20481) - dependabot
- Bump fast-uri from 3.1.5 to 3.1.7 (#20442) - dependabot
- Bump league/commonmark from 2.9.0 to 2.10.0 (#20427) - dependabot
