403 Unauthorized Upon Clicking "Auth History" or "Manage Users"
I’m getting a “403 | THIS ACTION IS UNAUTHORIZED.” when I click Auth History or Manage Users under the settings cog. I’ve checked the access_log, librenms.log, and journalctl, however the only thing I see that may be helpful is this from the access_log:
[30/Aug/2023:14:47:34 -0500] "GET /authlog HTTP/2.0" 403 3081 "https://librenms.aaaaaaaaaa.com/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36"
[30/Aug/2023:14:42:38 -0500] "GET /users HTTP/2.0" 403 3081 "https://librenms.aaaaaaaaaa.com/preferences" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36"
  1. Click on settings cog
  2. Click “Auth History” or “Manage Users”
  3. Error 403 Appears
librenms@LibreNMS:~$ ./validate.php
LibreNMS  | 23.8.2-20-g298d217a8 (2023-08-30T14:11:04-05:00)
DB Schema | 2023_06_18_201914_migrate_level_to_roles (257)
PHP       | 8.1.12
Python    | 3.9.2
Database  | MariaDB 10.5.19-MariaDB-0+deb11u2
SNMP      | 5.9
[OK]    Composer Version: 2.5.8
[OK]    MySQl and PHP time match
[OK]    Redis is unavailable
[OK]    rrd_dir is writable
Looks like the same issue after system updates. See murrant’s suggested fix here: Admin user roles
Unfortunately, still the same issue :confused: What other logs would help in determining the issue?
Same issue here. Murrant’s fix that was linked did not work for me either.
I am experiencing this issue as well.
The workaround from this post allowed me to successfully login and re-add the Admin role. Thanks!
bash-5.1$ /opt/librenms/validate.php
PHP       | 8.1.14
Python    | 3.9.16
Database  | MariaDB 10.5.16-MariaDB
SNMP      | 5.9.1
[root@LibreNMS ~]# cat /etc/os-release
NAME="Rocky Linux"
VERSION="9.2 (Blue Onyx)"
ID="rocky"
ID_LIKE="rhel centos fedora"
VERSION_ID="9.2"
PLATFORM_ID="platform:el9"
PRETTY_NAME="Rocky Linux 9.2 (Blue Onyx)"
ANSI_COLOR="0;32"
LOGO="fedora-logo-icon"
CPE_NAME="cpe:/o:rocky:rocky:9::baseos"
HOME_URL="https://rockylinux.org/"
BUG_REPORT_URL="https://bugs.rockylinux.org/"
SUPPORT_END="2032-05-31"
ROCKY_SUPPORT_PRODUCT="Rocky-Linux-9"
ROCKY_SUPPORT_PRODUCT_VERSION="9.2"
REDHAT_SUPPORT_PRODUCT="Rocky Linux"
REDHAT_SUPPORT_PRODUCT_VERSION="9.2"
I am noticing this problem as well. Went to check on one of the other users yesterday and found the error screen.
Is this something that will get fixed in the course of time via a new update, or am I now in a situation where I need to actively take control (e.g. by trying the fix provided by Murrant in the other topic)? ? ?
Thanks!
if you are seeing 403 unauthorized, but still see all your devices etc, then you need to run this part of the fix:
lnms db:seed --class='Database\Seeders\RolesSeeder'
lnms tinker --execute='Bouncer::refresh()'
These commands fixed my issue. Thanks Murrant.
Excellent. Worked for me.
Thanks again.
That worked for me as well! Thank you so much!
Thank you! It resolved my issue too.
When attempting to run the tinker command I get the following:
In Configuration.php line 632:
  Unable to create PsySH runtime directory. Make sure PHP is able to write to /run/user/1000 in order to continue.
I used the user add work around method. to correct the issue. Hopefully this PhySH issue doesn’t represent a bigger issue. I’m not familiar enough to know.
