419 | Page Expired
Keep getting “Error 419 | Page Expired” after logging in to web GUI. Tried ./daily.sh and ./validate.sh and show no issues.
librenms@LibreNMS:~$ ./validate.php
LibreNMS  | 24.8.0-90-gd2fb66d3d (2024-09-25T10:14:13-05:00)
DB Schema | 2024_08_27_182000_ports_statistics_table_rev_length (299)
PHP       | 8.3.11
Python    | 3.9.2
Database  | MariaDB 10.5.26-MariaDB-0+deb11u2
SNMP      | 5.9
[OK]    Composer Version: 2.7.9
[OK]    Redis is unavailable
[OK]    rrd_dir is writable
Laravel framework can give a 419 if the CSRF cookie can not be set/read.
Please check if your browser blocks that and if the FQDN you use to reach LibreNMS does match the host-configuration in Libre.
Thank you, Chris, for your response! I really appreciate it.
I’m still learning the more advanced areas of Linux. I checked the FQDN in /opt/librenms/config.php and $config[‘base_url’ is commented out.
I also checked the FQDN in /etc/nginx/sites-enabled/librenms.vhost and the server_name is set to librenms.domain.com; domain, of course, being my domain.
Would you mind letting me know how to check to see if the CSRF cookie is set and can be read? I greatly appreciate it!
Please check if the file “.env” in the librenms root-folder contains a line:
SESSION_SECURE_COOKIE=true
Then try to clear the session cache by runing command:
php artisan cache:clear
I checked SESSION_SECURE_COOKIE and it is set to true. I also ran php artisan cache:clear and rebooted, however still have the issue. :frowning:
Any other ideas?
Sorry, no other idea. Maybe the devs could answer what else could trigger Laravel to trash the sessions internally?
Have you set base_url?
