Please help to fix the issue:
config file:
rest: X.X.X.X:80
source:
default: http
debug: false
http:
url: [http://x.x.x.x:80/api/v0/oxidized](https://x.x.x.x/api/v0/oxidized)
scheme: http
map:
FATAL – : Oxidized crashed, crashfile written in /home/oxidized/.config/oxidized/crash
783: unexpected token at ‘’
curl -H ‘X-Auth-Token: zzzzzzz’ https://x.x.x.x:80/api/v0/oxidized
curl: (35) error:1408F10B:SSL routine
783: unexpected token at ‘’ [JSON::ParserError]
/usr/lib/ruby/2.7.0/json/common.rb:156:in parse' /usr/lib/ruby/2.7.0/json/common.rb:156:in parse’
/var/lib/gems/2.7.0/gems/oxidized-0.26.3/lib/oxidized/source/http.rb:21:in load' /var/lib/gems/2.7.0/gems/oxidized-0.26.3/lib/oxidized/nodes.rb:15:in block in load’
/var/lib/gems/2.7.0/gems/oxidized-0.26.3/lib/oxidized/nodes.rb:130:in synchronize' /var/lib/gems/2.7.0/gems/oxidized-0.26.3/lib/oxidized/nodes.rb:130:in with_lock’
/var/lib/gems/2.7.0/gems/oxidized-0.26.3/lib/oxidized/nodes.rb:10:in load' /var/lib/gems/2.7.0/gems/oxidized-0.26.3/lib/oxidized/nodes.rb:125:in initialize’
/var/lib/gems/2.7.0/gems/oxidized-0.26.3/lib/oxidized/core.rb:14:in new' /var/lib/gems/2.7.0/gems/oxidized-0.26.3/lib/oxidized/core.rb:14:in initialize’
/var/lib/gems/2.7.0/gems/oxidized-0.26.3/lib/oxidized/core.rb:4:in new' /var/lib/gems/2.7.0/gems/oxidized-0.26.3/lib/oxidized/core.rb:4:in new’
/var/lib/gems/2.7.0/gems/oxidized-0.26.3/lib/oxidized/cli.rb:13:in run' /var/lib/gems/2.7.0/gems/oxidized-0.26.3/bin/oxidized:8:in <top (required)>’
/usr/local/bin/oxidized:23:in load' /usr/local/bin/oxidized:23:in ’
Welcome to the Oxidized help section.
You are free to ask any questions surrounding Oxidized, it does not need to be specific to LibreNMS integration.
