I am looking to add roughly 48 billing ports for some switches that we have.
Don’t know if there is a way to do but I want one billing port per device and the a separate 95th percentile for each port on that device.
So for example Switch 1 has 48 ports with a mix of 1G, 10G, and 40G ports.
Billing port Switch 1
Graphs for each port and 95th percentile graph for each port.
I tried a single device and added approx 4 ports but the 95th percentile graphs are based on the combined ports not the individual ports.
Not even sure if it is possible or if I will have to get something written up on my own pulling graph data from LibreNMS to accomplish this.
I’m a little confused at what you want here but it sounds like you already have tested billing and it doesn’t do what you need. Theirs no other options that adjusts how billing works.
You can have the same port in multiple bills though, not sure if that helps you?
So I have Billing ports working no issues there.
We want to do 95th percentile billing port for a device and have it report each individual port of that devices 95th percentile.
Right now with the device I have added with 4 ports it combines them into one graph. I think I will have to come up with a script that pulls each device and 95th percentiles each based on the port speed i.e. 1G 10G etc… since they are mixed on the switch.
