A device is not displayed, but cannot add it again
I let LibreNMS discover almost all devices and it worked relatively well.
I had to add a few devices manually, but on the whole everything worked out fine.
However, I have a switch that is not displayed anywhere. If I want to add this manually, I get a message that this is not possible because the device is already available. I can neither find it on the network map nor in the device list and can therefore not delete it in order to create it again manually.
Question: Can I delete the devices elsewhere?
It is also strange that the neighboring switch at the port of the uplink to this missing switch shows a loop on the network map. There is definitely no loop in there.
it’s not appearing in the gui? have you tried removing it using cli? Usage: ./delhost.php
if you look in /opt/librenms/rrd do you see it there?
The only other thing that I can think is that maybe running a cleanup would help. Did you set any house cleaning options?
$config[‘rrd_purge’] = 1;
and try forcing a daily…Maybe Doc will show up with some better advice.
Check the box to force add it.
I am not sure, but I think I found the problem.
LibreNMS can only handle Devices that have unique Names (not just IP-addresses).
I changed the Name of that switch and was then able to add that SW to LibreNMS.
Unfortunatly the Network-Map show me still a loop at that place. Maybe I have to delete that switch and add it again afterwards?
So my 1st issue is resolved: I was able to add that device. The 2nd issue is still present: the network-map is showing a loop but htere is no loop.
can you post a screen shot of the map? I honestly have yet to see anything with LLDP not screw up somewhere no matter what NMS you’re using. Maps have looked screwy in whatsup gold, observium, netdisco and librenms.
Personally I stick to using network weathermap and the device dependency map.
